kz900 streetfighter.
- kzstreetfighter71
- Atlantic West Coast
17 Feb 2008 08:46
- mark1122
- Keep twisting it
Re: kz900 streetfighter.
17 Feb 2008 09:09
Looking great man. Tell us about what u have done . more pics please.:woohoo:
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- The Gringo
- ¡Usted no necesita otra motocicleta!
17 Feb 2008 09:17
I'm willing to give you the 6 weeks but you're on your own for the 700 bucks.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- kzstreetfighter71
17 Feb 2008 14:23
where do i start? she is a 78 kz900 motor, the frame is a kz1100, i used this cause i intend to put a big bore kz1000 motor in some day,plus the frame needed no gusiting or bracing cause its a sturdy frame as is, i chopped 5" off the rear and welded a brace in, split the lower end by cutting the center stand cross bar out and spreding the frame with a jack until tis 1 1/4" wider so i could fit the swing arm in, then welding 2 more cross braces in top and bottom one for the lower link and the other for the top of the shock, the lower sections of the frame spine wer cut off and re welded back in at a diferent angle to fit the kz750 tank on, the font and rear ends are cbr900rr, i got them at easy money plus it looks good on her, im tring to keep a classic look to her as much as possible, the tree pin of the cbr was machined so the bearings of the kz1100 would fit snug on them. new motor mounts wer made and thats where i am right now, iv been working on my 75z1 for the last 8 weeks more than her but im putting all my efforts into her now, a few problems still have to bo ironed out. iv now camera right now, i droped it at the toronto hot rod show ahmmmm.......
Post edited by: kzstreetfighter71, at: 2008/02/17 17:25
- wagonmaster69
- 78 KZ1000A2 / 82 KZ1100 Spectre
17 Feb 2008 17:10
That looks SWEEEET with that front end on it more pics more pics more pics did I mention like to see more pics :whistle: nice work.
- kzstreetfighter71
17 Feb 2008 17:54
thanks guys! im waiting on black wrap for the exhaust, gpz side covers, kz1000 tail ( not the duck tail type but the box type),going to make a seat pan out of aluminium and tool a leather seat for it,gloss black paint all round and gold leaf racing numbers. hmmm thats all for now:unsure: and a new digital camera:blush:
- hardr0ck68
- Who put the what in the where?
17 Feb 2008 18:00
When you used a jack to spread the frame, how could you be sure that both sides moved equal amounts? Is it possible that one half bent 1" while the other only took 1/4"?
I am wondering how to do something like that and insure precision?
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- kzstreetfighter71
17 Feb 2008 18:21
we used a car jack like this one and cut so that the surface areas wer the same on both sides.
before we cut the frame we put the jack into place and applied a little preasure with it so when we took the piece out it didn'nt warp, then i measured the exact middle of the frame dropped a sting with a weight attached and as we opened the jack a small bit a time we measured the distance from each side of the frame to the string. we welded in the replacement brace before taking off the jack. there is a small diference to either sice but its onlt an 8th 0f an inch, figured it was an exceptibal varient. my biggist problem now is the swingarm axel holes are at a slightly dipped angle, this is the only head scracher im faced with, any ideas out there?
- mark1122
- Keep twisting it
16 Mar 2008 09:27
can u heat the area and put a bar in the axle hole and bend it back to square?u will need a longer axle .maybe u could rebore it true, and large for a bigger axle?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- NebrMotoPartsInc
17 Mar 2008 22:11
That is awesome!!!!
Looks pretty mean slammed like that!
