1980 Z1
- PLUMMEN
Re: 1980 Z1
13 Feb 2008 09:25
i remember being educated and arguing till i was blue in the face about the 79 b3 motors being mkII motors,then i found out they were built with small pin 78 style cranks.the b4 motor is definately a mkII in sheeps clothing as they say,though you are still going to have a hell of a time hurting the crank in a 79 or older unless youre really getting into it;)
- Jack
Re: 1980 Z1
13 Feb 2008 14:35
smclem wrote:
And I will take any 79-80 std. or shaft models,OSR can have the LTD's...Please ship all undesireable 80 LTD engines to me please.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- Jimbo302
Re: 1980 Z1
13 Feb 2008 15:44
I see, I assumed the Z1 moniker lived on after that. So, this is a mkII model engine in a B model bike? Is it work trying to get running? I am mostly interested in the engine, and if it is a mkII then if has the larger crank and is possibly a good build starting point?
I'm having the owner send me the vin so I can tell what exactly it is. Would the whole thing, as parts, be worth $400us to someone that wanted to build a kz?
- PLUMMEN
Re: 1980 Z1
13 Feb 2008 17:16
any kz1000 is worth that if it will turn oer and is mostly there;)
- Jack
Re: 1980 Z1
14 Feb 2008 05:56
Jimbo302 wrote:
MKll cases are selling for $250-$400 alone and the cranks about the same, so ya $ 400 for the whole bike is a good deal.I see, I assumed the Z1 moniker lived on after that. So, this is a mkII model engine in a B model bike? Is it work trying to get running? I am mostly interested in the engine, and if it is a mkII then if has the larger crank and is possibly a good build starting point?
79 KZ 1075 MKll
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- PLUMMEN
Re: 1980 Z1
14 Feb 2008 09:49
as anybody ever actually come up with a cut off line where the mkII cases and crank are actually beneficial hp wise anyway? i remember the old stories about kawasaki guaranteeing the mkII cranks for up to 200 hp by just welding the pins,but where does it fit into the real world?
- 900cows
- Jack
Re: 1980 Z1
19 Feb 2008 12:26
PLUMMEN wrote:
The modified cases I've seen have typically been ProMod or especially Funnybikes, the bikes you find with big nitrous or boost. Most NA or small nitrous will only need a good set of stock MKll cases with some type of crank support. Lots of 225-250 hp TG bikes out there with stock MKll cases and big pin/ welded MKll cranks.
79 KZ 1075 MKll
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- IowaKZ
- '80 G1 Classic
Re: 1980 Z1
19 Feb 2008 19:45
The only way to be sure what you got is to check the frame numbers.
the 1980 G1 classic has a side cover emblam with Z1 on it. That might be what the seller was refering to. This model looked a lot like the LTD with the mags and small chrome front fender.
There was no tail piece with this model, but I'm sure someone could find one to fit (and match up the fairing).
The only thing that makes me doubt this is that in the pictures the engine looks unpainted, but on the G1 classic, the engine is painted black with chrome side covers.
1980 G1 Classic
Bettendorf, Iowa
Bettendorf, Iowa
