1975 Z1b. low and long(ish)
  • kzstreetfighter71
  • kzstreetfighter71's Avatar Topic Author
  • Atlantic West Coast
04 Feb 2008 21:38
#192814
this is my z1. bought 2 weeks before the x-mass hols. she was in rough shape, she'd taked a pounding over the last few years, running well enough but bleeding from the head gasket.
Post edited by: kzrider, at: 2008/02/05 03:14
  • kzstreetfighter71
Re: 1975 Z1b. low and long(ish)
04 Feb 2008 21:44
#192816
stripped down and repainted with truck bed rino style paint, nice finish on it, a dull black with nice texture. bolted on a 5" overstock arm and 2 brake stays for struts. she is goin to have accel coils and leads.
  • kzstreetfighter71
04 Feb 2008 21:49
#192817
front end on her. i went with a kz750 front end because the overall lenth of the fork was 1" less and the forks stance was a little wider, iv set it up in a way that i can adjust the hight of the bike by rising or lowering the forks i the trees. i have a set of set-backs for the bars so i have clearence when i mount them. the clocks are lowered and the headlight brackes inverted to lower the level of both.
  • Shoe48
  • Shoe48's Avatar
  • Live each day as it is your last
05 Feb 2008 07:21
#192860
  • kzstreetfighter71
05 Feb 2008 18:00
#193038
wow shoe, how did you you that?
  • kzstreetfighter71
05 Feb 2008 18:02
#193040
finished lining the tank and tail, 2000 sanded and ready for graphics and clear coat.
  • kzstreetfighter71
06 Feb 2008 08:27
#193106
motor back in, head back on, cbr900rr rear sets mocked up, time to do the timing. fingers crossed. i may need yer help lads.
  • StreetfighterKz
  • StreetfighterKz's Avatar
06 Feb 2008 08:43
#193110
Did you drill through the frame tubes to mount the rear sets?
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • kzstreetfighter71
06 Feb 2008 10:02
#193120
yes but i kept the hole size to a minimum, the lower hole is under the strongist points in that area and im going to have a strenghining strut from the upper hole to yhe lower hole of the motor mount.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
06 Feb 2008 13:28
#193145
if you would build some sleeves to fit through the frame and weld in,they would be stronger than the unmolested frame tube was.just a thought.
  • kzstreetfighter71
06 Feb 2008 15:06
#193154
ya sleves are being made tonight and welded in this weekend but the subframe only needs to support my fat ass, iv shrtened the seat and tail by 4" to make it a single seat.
  • kzstreetfighter71
06 Feb 2008 18:18
#193172
just finished re-intaling the cams, that was a 2 1/2 hr headake but its all good now. pheeww
