OMG .. ALWAYS take the parts bike!!!
- Skypilot54
25 Oct 2007 17:00
ALWAYS get the parts bike.
So I was tinkering with FrankenBike for the last week, messing with the carbs. For some reason, it decided it wasn't going to start. It finally fired with the air mixture screw at 1/4 turn out. It just didn't seem right, since the recommended starting point was 1-3/8 turns out. I pulled the carbs AGAIN, cleaned the carbs AGAIN, and after some reading .. I realized the choke sliders were missing the flaps. Why didn't I see this before??? So I went to the carbs that were on the parts bike. All four choke sliders had the original flappers. And .. I could change the sliders without removing the carbs. Karma was on my side today. So I changed the sliders, and BOOM, started right up. I still need to tweak it a little and balance everything out, but I'm a happy camper. I also did the coil mod (Thanks WG), and I know that is making a difference too.
I've probably spent less than $400 in new parts so far getting FrankenBike on the road. Everything else came from the part bike.
- harm
- Tom
Re: OMG .. ALWAYS take the parts bike!!!
25 Oct 2007 17:49
That is cool it worked out. Those choke plates on the 550 carbs are known for falling off and getting sucked thru the motor. You may want to make sure the ones you got off the parts bike are securely intact. 3 of the 4 were missing on my bike so i glued them shut and use the choke lever position to allow some air to come into the carbs. It seems to work pretty good:)
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
- loudhvx
25 Oct 2007 21:16
harm wrote:
I have a little mod you guys may have already seen. I found it helps with the warm-up process. www.geocities.com/loudgpz/GPZchokeScrewMod.html
I have the same carbs as you guys, but they are just painted black. Sorry if I've already posted this for you.
I've been wanting to try this exact thing as an experiment. Thanks for the info! Luckily, so far all of mine are intact (knock on wood).That is cool it worked out. Those choke plates on the 550 carbs are known for falling off and getting sucked thru the motor. You may want to make sure the ones you got off the parts bike are securely intact. 3 of the 4 were missing on my bike so i glued them shut and use the choke lever position to allow some air to come into the carbs. It seems to work pretty good:)
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- RonKZ650
25 Oct 2007 22:00
I don't often read the projects forum. From what I can see, projects "are" the parts bikes. I guess buy the parts bikes to fix other bikes that should for all intensive purposes have been parts bikes?
- mariozappa
26 Oct 2007 05:17Those choke plates on the 550 carbs are known for falling off and getting sucked thru the motor.
How odd. My buddy's 550 has the same problem.
1977 KZ650C1
and the KZ650/KZ750 Conversion
- harm
- Tom
26 Oct 2007 08:31
Actually, when i took the top end off my bike i could see where some of the pieces bounced around on the top of the pistons before leaving the combustion chamber:woohoo:
A couple of the rings were tight on the piston as a result of the dings.
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
- loudhvx
26 Oct 2007 19:13
RonKZ650 wrote:
All four of my bikes started as parts bikes, but don't worry, at least one will be totally stock including original paint. I don't have the big bucks to throw around for an actual complete, and running bike.
:laugh:
1981 KZ550 D1 gpz.
Other links.
Other links.
- CoreyClough
- GPz550 Addiction
26 Oct 2007 21:25
I went to look at a parts bike, and brought the $300.00 limit my ATM would let me take out, just in case. I wasn't even in the market for a spare bike. Once there and after I saw whay was on it, I gave him more than he was asking for it, and picked it up that weekend. Later I found out more about this bike(with all the goodies, and only 5000 miles on the speedo. Too bad it has been sitting outside for 10 years, but the original owner had it on the track. Score, was the aftermarket reservoir Fox Shock, Telefix Fork Brace, Clip-On Bars, braided brake lines, Megacycle Slotted Cams, 615cc kit, ported head, Moriwaki Exhaust, and Yoshimura Ignition Cover. $260.00. Everything was there, and I haven't got into the front forks yet.
Always take a parts bike!!!
Post edited by: CoreyClough, at: 2007/10/27 00:26
'85 GPz550(ZX550-A2)
