I've only ever known of 2 people trying to start a BBQ grill using Gin. Both were on the same day. Both were in the process of becoming engineers. At least one of them, while not a rocket scientist, is a now nuclear engineer. That's pretty close in my book.
Anyway......... here are some updates on the project.
I grabbed an old disc brake wheel from the junk pile behind my shop and set out to clean it up a bit.
I still need to hit a couple small spots but it's just about ready for clear coat.
The "chopping" has begun. I got the bottom frame rails sitting level but still have to finish moving the top anchor point on the down tubes. It looks like the down tubes will end up with about a 3 or 4 inch stretch. Old timers will remember that this 440 has the front forks from a KZ750 LTD-4 wich are about 3 inches over the length of the original 440 front end.
The pre-bent steel arrived for the hardtail. It was a lot cheaper than buying a good tubing bender. The sprocket for the new rear wheel is here too.
No, the 2x4's are not a redneck frame jig. I just wanted to hold the frame neck at a particular height. The engine will come out before final welding of the frame. I wanted to leave it in to hold certain things in place, for now.
I had hoped to use the stock gas tank but I don't think it will work out after all the frame mods are done.
