1978 KZ650 chop project...
- Kingcobra
08 Sep 2007 22:19
I'm new to your forums... hope this kind of thing is accepted here...
started with this free bike... 9,000 miles, a victim of outside elements. oil change, new plugs and a battery and she fired up...
got it to this point fairly easily... sportster tank, hacked frame, new tires, makeshift seat...
now I'm takin it a step farther...
painted the frame tonight...
- ten6
Re: 1978 KZ650 chop project...
08 Sep 2007 22:22
I like your work so far. The frame looks cool. I was never a big fan of that style tank but as long as you like it...
I can't wait to see the finished product. Keep the pics coming.
Michigan City, Indiana
Firefighter MCFD IAFF Local #475
(3) KZ650s (1) 1996 Vulcan 1500A (1) 1978 KZ1000 (1) 1986 Yamaha Radian 600
2000 Dodge Ram 4x4
1960 Chevy Bel-Air
2000 Dodge Ram 4x4
1960 Chevy Bel-Air
- Kellen79_650
09 Sep 2007 07:52
Interesting how you are setting the seat up with the mono-shock. My project is hardtailed as well but with a more traditional backbone. Check out my posts, there are pictures. I haven't decided on mid or forward controls. The thing I was worried about with forward controls is having to wrap my legs around the motor. Didn't seem like it would be too comfortable. How is your setup working out? Looks like you used some of the stock equipment to fab the controls. Good to have you on the site. I was starting to get lonely as one of the few hardtail guys.
"In the beginning of a change, the Patriot is a scarce man, Brave, Hated and Scorned. When his cause succeeds however, the timid join him, for then it costs NOTHING to be a Patriot."
~Mark Twain
~Mark Twain
- OKC_Kent
09 Sep 2007 08:24
Kingcobra,
I like the first incarnation you had, looks good. That is a hand shift, right? How did you clutch and shift? Or do you just use the clutch at stops?
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
- Kingcobra
09 Sep 2007 09:30
thanks guys...
the seat pan is next... makin it out of 1/8 steel and it will bolt to that plate you see. the spring is too stiff (1000 lbs/in) so I'm looking for a softer one. still need to finish wiring and rebuild the leaky carbs.
I use the clutch only when stopping, starting off and downshifting... yes hand shift.
the forwards work very well... watch when you wear shorts as the head gets dam hot. you will burn yourself a few times til you learn to remember that lol...
I used the rear pags and part of the foot brake lever and some misc rod and tube to make my forwards.
here's an update...
here's an update...
- Mark Wing
09 Sep 2007 13:19
Looks killer so far. I think it's more than one more step, it's more like a big jump farther. Keep posting pix.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- Kingcobra
09 Sep 2007 18:39Please Log in or Create an account to join the conversation.
- CSR1000_Mike
10 Sep 2007 06:57
I am likin' this one! I admire the fact that you are doing the work yourself and that you weren't afraid to get out the sawzall and welder and make it the way you want it! Are you going to build a battery cover or leave it in the open? Myself I would build a forward foot shift for it instead of the hand shift, but I like nailing the throttle a lot too... I am looking forward to seeing the completed bike!
1983 Kawasaki KZ1100 LTD
1978 Honda CB550 project
1973 Yamaha TX650 project
- CSR1000_Mike
10 Sep 2007 06:58
- Kingcobra
- ten6
11 Sep 2007 19:10
O.K.it looks great but I have to ask...what's the deal with that funky strut on the rear fender? Kinda takes a lot away from a beautiful bike...
2000 Dodge Ram 4x4
1960 Chevy Bel-Air
2000 Dodge Ram 4x4
1960 Chevy Bel-Air
- Kingcobra
12 Sep 2007 15:21
they are going to be painted... will look better then.
