rear end kinda mock up
- donthekawguy
05 Aug 2007 21:08
I threw the new swing arm and wheel on to see what it will look like. The wheel is a 18x5 and the arm is a 6 over. I'm hoping that a 190 tire will fit in there.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- Mark Wing
Re: rear end kinda mock up
05 Aug 2007 21:35
Looks good. Are those spokes going to be strong enough?
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- PLUMMEN
05 Aug 2007 22:08
cool !
- donthekawguy
06 Aug 2007 01:24
Mark Wing wrote:
I hope so. It should be strong enough. I got the wheel from a drag racer on dragbike.com. BTW-FREEBIE!
Mark
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- StreetfighterKz
06 Aug 2007 04:27
5" rims are not big enough for a 190. You'll round the tire over too much. If you want to run a 190, I suggest a 6" rim but a 5.5" will do.
Later, Doug
Post edited by: StreetfighterKz, at: 2007/08/06 07:28
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- donthekawguy
06 Aug 2007 05:43
Damn how about a 180? Or what size would work? I have 9 1/4 inches to fill in the swingarm.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- StreetfighterKz
06 Aug 2007 06:24
A 180 is possible. A 170 or even a 160 will give you a decent footprint. My 1000 has a 160 on a 4.5" rim. Normally a 4.5" goes with a 160-170 tire, and a 5.5" has a 180-190 tire. So a 5" could have a 170-180 tire.
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- racer54
06 Aug 2007 12:04
If you looking for a wide footprint, figure out what size tire is made for your rim and then use the next smaller tire. This will flattenout the tire for a wider footprint. I use a 130 on a 3.5 rim (made for a 140+ tire) and this flattens tire out for more rubber on the road. Lots of guys will use a 5.5 rim and use a 170 tire to flatten profile out, although that size rim is used for 180-190 tires. Of course, we do this for better traction and if you want to use the bike for cornering, you want to go the other way.
