KZ1000R1 clone project
- jcote75
03 Aug 2007 11:23
Hi everyone,
As many of you already know, I'm looking to build an elr clone to keep company to the Z1100R1.
I've been searching all over the web to find a good post for this type of porject but didn't find anything with all the information I needed at the same place.
Well here it will be!
This will be my winter project but I'm acutaly picking all the info I can in order to have a identical replica of an 1982 model. I know it will be a replica of a replica and it will never worth the money and time I will invest in it but still, this is my passion and hobby. Some people play golf and give a lot of money only to kick a little white ball so.....
Ok here is the project:
Got a 1982 GPZ1100 and a 1981 KZ1000J. Both have an elr seat and 4/1 Kerker exhaust. From what I've found, the ELR is made frome parts of these 2 bikes. I'm using the GPZ frame since it is all in regulation. (the Kz haven't run for at least 8 years).
Usaualy, an ELR is a J bike with GPZ bodywork, oil cooler, footpeg, front brake and master cylinder and shifter linkage. The shock, seat and Kerker is unique to the ELR. Lucky for me, I've just bouth a pair of shock from a Zephyr which are the same except the color.
Since I'm using the GPZ as a base, I'll transfer the complete front end, motor, gauge, carbs, airbox from the KZ to the GPZ.
Here is the picture of the GPz. It will be completely tear down in maybe a month and send the frame to powdercoat painting.
I'll try to take the most picture I can.
Feel free to add your comments.
Tks,
Joce
Tks,
Joce
- Mcdroid
- Gone Kwackers
Re: KZ1000R1 clone project
03 Aug 2007 11:52
I'm watchig and smiling...just keep posting the occasional picture...
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- jcote75
17 Oct 2007 08:22
Finaly starting the project!
The GPZ is now totatly strip down and all parts ready to go to the powdercoater. I'll post some picture when done.
As already mention, I'm using a GPZ1100B2 and a KZ1000J in order to build a KZ1000R1. One question for all the expert: I'm taking the fork and triple tree from the KZ and instaling them on the GPZ frame. The reason for the fork is that I want to have the air bleader on top. I notice that the brake rotor are not the same size so I'm thinkin about using the bottom leg of the GPZ (Galiper doesn't mount at the same place) and the tube of the KZ. Is this something possible? The KZ tube seem to be longer of about half an inch, will this be a problem?
Here is a picture of the KZ.
- jcote75
23 Oct 2007 09:18
I'll try to solve this by myself.
Seem like the triple tree from the KZ grab the fork a little further than the GPZ. SO I don't think I will have a height issue.
The only thing is that the distance between the wheel is gonna be a bit longer.
I'll try to take some picture this week to show you what I mean.
For the leg fork swap, I dismantle both of them to compare and see if it's possible.
- Bad Kaw
- Flying Squirell
24 Oct 2007 14:39
Mcdroid wrote:
Yep! What he said!
BTW: cool project!
Yep! What he said!
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
70 Kawasaki KV75
- jcote75
05 Feb 2008 10:54
Have been pretty busy lately but here is a little update on this project.
Everything is back from the powdercoater and it's all pretty nice. Cost for sandblast and powdercoating was 200$ which I think is OK. Had near 40 part to paint.
Has you can see on the picture attached, Ive started to put everyting together. Front end was partly install last night and motor block is going in tonight. I'll try to have some newer picture soon. Glad that it's starting to look back as a moptorcycle. Was in many box a month ago!
Few questions left, I've seen a lot of people putting GPZ cams in the Kz head. Mainly on some 750 motor.
I will have the choice with some kz1000j cams and gpz. Which one should I put and why?
The motor that I will be using is a 998cc from the Kz1000J. It has the first oversize. Will be using a 4 in 1 Kerker KR with stadard Mikuni cars.
Next question is for the motor covers. I will have them powdercoat ut was wondering what do I do with the clutch cover. DO I leave the oil lever lense there? Will it resist the heat?
Thanks for your input to everyone.
Joce
Joce
- Bad Kaw
- Flying Squirell
05 Feb 2008 11:54
jcote75:
I have some "guesses", but nothing that I know for sure. I'm guessing the GPz cams will be hotter, and who doesn't want more power!
With the motor cover, if you can source a new oil-sight-glass from a Kawasaki dealer, it can't be that much money, why not just go ahead and replace it? I mean, you're going this far and making a nearly perfect beast...just pop for the new window and you'll sleep better.
Keep the pics comin'...love it so far!
-KR
-KR
78 Kawasaki Z1R
70 Kawasaki KV75
70 Kawasaki KV75
- DrWhizBang
05 Feb 2008 12:57
jcote75 wrote:
Hey Joce, who did you coating and what was the turnaround time?
KZ650C2 w/810CC in Saint John, NB
-- a sleeper, methinks.
- jcote75
05 Feb 2008 13:06
Here is the wesite of the guy.
www.fabricationstremex.com/service.html
It is near Quebec City and does a lot of ATV.
Took 2 weeks to get everything done. Note that the sandblasting was done by another company.
The cost for the powdercoating was 120$. This is low since he wait to have a lot parts of the same color to do the job. SO you don't pay a minimum for the set up.
Other color are available but pricing and delay are different since gloss black is a common color.
The guy speak english so the best thig is to call him directly.
- jcote75
07 Mar 2008 08:39
Here is a picture of where I'm right now!
Put the body work on to see if everything was fitting right before starting the paint job. Everything fit fine + give a good boost seing all this looking like a motorcycle again. I've receive a set of decals from the comapany "reproduction decals". Seem to be top quality. Can't wait to have them on.
Still waiting for the motor covers and bottom fork to come back from the powedercoater. Hope it's gonna be next week.
Meanwhile, cylinder and head should be install this week end. Got a few helicoil to install but nothing major (still got my finger cross).
Carbs will be doing a long trip to Wiredgeorges for rebuilt.
Everything going fine but not 100% sure it's going to be ready for spring.........
Anyway, I,ll try to post some picture more often if I can.
Thanks everyody for your help
Post edited by: jcote75, at: 2008/03/07 11:40
07 Mar 2008 09:18
lookin good!keep us in the loop.
- Bad Kaw
- Flying Squirell
17 Mar 2008 16:03
Lookin' good! Got more pics, yet?
-KR
-KR
78 Kawasaki Z1R
70 Kawasaki KV75
70 Kawasaki KV75
