1976 z750 B
- kzrider
- Administrator
Re: 1976 z750 B
14 May 2007 01:48
Biquetoast wrote:
Thanks for the tip! Can't believe I didn't think about that myself :blush:
It looks like I'll go for the Mac 2 into 2.
Got the seat on, by the way. It fits. Sort of... When latched, it doesn't quite line up where the rear rubber dampers touch the frame. Have to lift and slide the right side into place in order to latch properly. I'll get some pictures of it, but my guess is that this is as good as it will get. One thought I had was minor differences between the KZ and the European Z that I have. Seat is for the American model. Thoughts on this?
*If* you're going to go with stock pipes and replacement mufflers, make sure you're looking at up-swept mufflers.
1976 Z750 B1
1980 Z1000 MkII A4
1980 Z1000 MkII A4
- kzrider
- Administrator
Re: 1976 z750 B
14 Apr 2008 12:44 - 14 Apr 2008 12:45
After 3 days of wrenching, the beast is now put back together! Still needs to clean it up a little, but man what a great feeling it is when you finally get to fire up a Z that has been asleep for a year.
Here's what's been done over the past 72 hours:
Tomorrow is probably the most important day in this Twin's life (or at least it's pretty important to me
). I'm going to get it registered, and hopefully the DMV will be ok with the shape the bike's in. They are really strict when it comes to brakes, lights, and noise. Everything works just the way it did when it was new, but the noise... Damn those MACs are loud! I'd put something in the mufflers if I knew I could get it out again, and more importantly that it wouldn't blow out in the face of the DMV representative... I'll just have to cross my fingers and hope the guy is in a good mood.
Wish me luck, and I'll go out and see if I can shoot a couple of pics for you. I only have my cell phone camera though. Oh, I'm at my brother's farm, so he's responsible for the mess in the garage...
- Cleaned up the electrical system (generator, lights, switches, connectors, etc.) with new heatshrink where needed.
- Installed new ignition breaker assembly and set the timing.
- Spent hours removing gasket material and installed new generator cover and cluctch cover.
- Installed MAC 2-2 exhaust system. A pain to get the mufflers to slide over the pipes, but gives a pretty good look and an ok fit once installed. I sprayed the insides of the pipes with a little muffler paint to avoid blueing, but I think I was too cheap with the paint as the pipes already start to discolor a bit after only riding less than a mile + idling when adjusting the timing.
- Installed new K&N air filter
- Cleaned, polished, and installed front and rear fender.
- Changed the headlight rim
- Installed professionaly painted tank, sidecovers, framecovers, and duck tail. It was damn expensive, but wow! If anyone in Norway wants a 99% matched original color paintjob, go pay Robert Walter at Custom Color in Ski a visit. I did't ask for a macthed paint job, I just said dark red with the pinstripes I got from Reproduction
Decals. But I think he did some research, because it looks pretty close to original. He's done some amazing work on Z900s and Z1s that he showed me, and I really could not tell the difference between those and the original. - Installed new fuel lines and filters
- New handlebar and grips
- Changed brake fluid, and bled the brakes
- Clutch adjustment
- A lot more I can't even remember right now, as I'm sitting here with a grin on my face knowing that the bike runs like it probably never has before. Even though it's a bit loud, the sound is to die for.
1976 Z750 B1
1980 Z1000 MkII A4
1980 Z1000 MkII A4
Last edit: 14 Apr 2008 12:45 by kzrider.
- kzrider
- Administrator
- kzrider
- Administrator
- kzrider
- Administrator
- mariozappa
Re: 1976 z750 B
14 Apr 2008 13:26
The bike looks great!
I know the awesome feeling you get from putting something back together and it runs better than it has in years.
I wish I never sold my 76 twin
1977 KZ650C1
and the KZ650/KZ750 Conversion
- btchalice
Re: 1976 z750 B
14 Apr 2008 14:52
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- KZ250LTD
Last edit: 20 Dec 2011 04:10 by KZ250LTD.
- steell
Re: 1976 z750 B
14 Apr 2008 15:38
If you still have the problem with seat alignment, just loosen the bolts that attach the hinge to the seat, line the seat up then tighten the bolts.
- Biquetoast
- King Jeremy The Wicked
Re: 1976 z750 B
16 Apr 2008 17:00
It looks great!
...of course, don't forget to inpect your starter clutch someday soon before it explodes on you... I don't know if you read all that stuff I posted some time back about mine that broke to bits.... I'm on a mission to warn all 750 twin owners...
:blink:
:laugh:
:blink:
:laugh:
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- kzrider
- Administrator
Re: kzrider fixes what's not broken...
31 Jan 2011 11:37
Ahh... my little big twin... It just hasn't gotten the attention it needs and deserves. I haven't ridden it much either, especially since I got the the MkII. And apart from the initital once-over it got a couple of years back, I'm afraid it's been a bit neglected. Not that it doesn't run or look decent, but I think it can do a lot better. Hence the new thread title.
I hope the KZ Gods don't strike down on me for breaking that cardinal rule...:ohmy: :lol: Anyway, a couple of nights ago I started tearing it down.
The to-do list will probably grow a lot over the next few months, but here goes:
Before I start with the detail pictures, I think a short picture recap is in order...
Here's the bike when I bought it in 2007:
- First order of business: The flake painted frame! It's been bothering me ever since I bought the bike almost 4 years ago. It looks awful! New paint or powdercoat.
- Front suspension. Leaking oil again, as the pitting in the travel area of the tubes have blown the seals yet again. I've got a brand new set of fork tubes, and that should finally fix the problem.
- Electrical system. 35 years of quick fixes from previous owners has taken it's toll...
- Brakes. Again, they work, but the current stopping distance from 100 km/h is not what I'd call satisfactory :blink:
- Carbs. Need a good service.
- Hopefully convert to electronic ignition if I can round up the parts needed.
- Top end service. I've got a NOS set of jugs as well as new pistons and rings that I bought a long time ago. Will get a new cam chain as well. We'll see what else it needs when I get there
- Starter clutch inspection. Biquetoast's warnings HAS made an impression, and even though I did a quick check a couple years ago I'll be more thorough this time.
- Paint or powdercoat a lot of smaller parts like calipers, switches, battery box, stands, etc.
1976 Z750 B1
1980 Z1000 MkII A4
1980 Z1000 MkII A4
- kzrider
- Administrator
