1300 Street Cruiser
  • KZQ
  • KZQ's Avatar Topic Author
  • Administrator
  • Administrator
1300 Street Cruiser
10 Mar 2007 06:48
#118901
Hey Folks,
I've got the parts I need to finish putting the rear end on my 85 1300 so now I'm planning the radiator relocation effort. To do that I need to learn how to weld aluminum tubing. Here are my first attempts.
Just some practice on flat stock.
Post edited by: KZCSI, at: 2007/03/10 09:49
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • KZQ
  • Administrator
  • Administrator
Re: 1300 Street Cruiser
10 Mar 2007 06:52
#118902
Here's my practice piece on tubing.
These tubes are only 25.6mm (1 inch) in diameter. In order to do the job I'll need 35.2mm (1 3/8 inch ) tubing. I've already found the tubing. What I need is a source for is 35.2 mm elbows made from relatively thin wall aluminum tubing.
Does any body know of a source?
TIA
KZCSI
Post edited by: KZCSI, at: 2007/03/10 09:58
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • KZQ
  • Administrator
  • Administrator
10 Mar 2007 07:01
#118906
The proper name of the parts I'm needing is "weld ell". If I could find a source of aluminum hand railing parts that would be a good start.
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • wireman
  • wireman's Avatar
10 Mar 2007 10:52
#118975
have you tried a welding shop for the parts?or how about welding up some aluminum rods into a 90 to go inside of the tubes instead of outside;)
  • 77KZ650
  • 77KZ650's Avatar
10 Mar 2007 11:22
#118981
just curious, why cant you use a rad hose like a car or new bike? braided stainless steel hoses look nice!:)
07 MDP Rookie of the Year
  • wireman
  • wireman's Avatar
10 Mar 2007 12:45
#119009
oopsies:S i thought you were building some sort of mounting bracket to mount the radiator ,my bad!;)if you want to use it as radiator line how about getting some rigid aluminum electrical conduit and bending it into the shape you need?;)
Post edited by: wireman, at: 2007/03/10 15:48
  • KZQ
  • Administrator
  • Administrator
10 Mar 2007 14:10
#119033
Thanks wireman,
I hadn't considered aluminum conduit. I could bend it with a mandrel bender. I have several electrician friends who might loan me the use of one.
Thanks
KZCSI
Thanks
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • wireman
  • wireman's Avatar
10 Mar 2007 16:21
#119053
it actually bends pretty easy with a regular conduit bender if you dont go over 90 degrees too fast;)
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
10 Mar 2007 16:26
#119057
I don't know about aluminum, but I will tell you what I heard today from a friend of mine who works at the state office building. He said that fuel may reach near $4/gallons this summer, but more importantly the price of steel (didn't ask about aluminum) is going to double wihin a month.
I've known this guy to be wrong...but only very rarely (the stuff he talks about is speculation of government officials...so there ya go). I don't know how much your project is going to cost you, but if there is anything to what he said, you might take that into consideration.
Sure looks like you picked up the 'knack' for aluminum welding pretty quickly...well done.
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
  • KZQ
  • Administrator
  • Administrator
10 Mar 2007 21:24
#119129
Hey Wireman,
I realize that 3/4" and even 1" can be bent by hand, but can you also handle 1 3/8", probably 1 1/4" by hand as well?
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • KZQ
  • Administrator
  • Administrator
07 Apr 2007 19:09
#127534
I ended up going with 1 3/8" stainless steel tubing because it can more easily be bent to 4" radius. I picked up the pieces and parts this last week and could hardly wait till Saturday to get to fabbing up the tubes.
I was right the coolant tubes look somewhat like extra exhaust pipes.
I still have to make the connections at the rear end and add an air bleed at the top before I really weld them up liquid tight.
KZCSI
Post edited by: KZCSI, at: 2007/04/07 22:12
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • scumbag
  • scumbag's Avatar
  • Lewd, Screwed, and Tattooed
07 Apr 2007 19:39
#127547
that makes teh front end look sooo sooo sooo much better...thumbs up to you indeed...so where are you going to mount the rad?
sept.1976 kz650
1980 kz650
