yet another zed...
- solomrus
Re: some progress.
22 Mar 2007 08:55
yeah, i did too. 8^)
i'm not finding much cermet info online. gonna keep looking.
--r
--r
198o kz1ooo Bravo Four
- 77KZ650
Re: some progress.
22 Mar 2007 10:02
solomrus wrote:
maybe a dremmel would start off the process and allow what you were trying beforewon't work to cut the center out of the other sprocket tho.
07 MDP Rookie of the Year
- Bad Kaw
- Flying Squirell
Re: some progress.
22 Mar 2007 21:31
So Russ,
I think I should change my forum monicker to "insanely jealous bastard from south of Russ's uber-zed" ... dude, great googly moogly, that bad unit is starting to 'gel'.
Brilliant engineering applications! Brother, you da man!
Post edited by: Bad Kaw, at: 2007/03/23 00:33
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
70 Kawasaki KV75
- steell
Re: some progress.
22 Mar 2007 22:06
MSC has them
HERE
But you also need indexable tool holders Like these
Machining do get expensive, don't it
- solomrus
Re: some progress.
22 Mar 2007 22:25
muchas gracias, senor!
you're gonna have to ride it. i'm still planning on coming down for the open house.
it should be running before then. it'll be a shakedown ride.
--r
--r
Bad Kaw wrote:
So Russ,
Brilliant engineering applications! Brother, you da man!<br><br>Post edited by: Bad Kaw, at: 2007/03/23 00:33
- solomrus
Re: some progress.
22 Mar 2007 22:30
machining isn't so bad...
machine TOOLS, on the other hand...
dayam.
this is basically my lathe:
www.lathemaster.com/LATHEMASTER9x30Lathe.htm
mine's an older seig, 9x22, and green. bought it from another hobbyist here in town. paid for itself over, and over, and over...
i think, for the cost of that tooling, i will pay joe to make this one.
that guy sells some indexable tool holders, but i think this is a better option for now.
--r
dayam.
--r
- steell
Re: some progress.
23 Mar 2007 05:50
My desire for tooling far exceeds my ability to pay for it.
It's an unending battle, do I spend the money on bike parts, or do I spend it on tooling?
There is never enough for both
I have old American iron (in good condition), a 12x36 Sebastian, a Gorton vertical mill, and a Delta Rockwell drill press.
- mark1122
- Keep twisting it
Re: some progress.
25 Mar 2007 02:24
Solomrus.Love your bike ,looks GREAT. Going back a bit to the triple crown.Would do you think it would be any easier to cut off the zx6 stem drill out and press in kz stem then weld?Rather than make a spacer? I'm getting close to doing zx12 trees on my kz.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- solomrus
Re: some progress.
25 Mar 2007 20:31
mark1122, thanks man!
in regards to your plan: i think what you propose is just as viable as what i did. the 636 stem that i used was alloy, so welding to that was not an option, were i to use that bored out.
there are different ways to skin the cat, i guess is what i am saying. whatever is best for your capabilities.
steell: you have stated it succinctly. 8^) the key is to make the tooling pay for itself.
sounds like a nice little shop you have. no mill, here, yet... it's one of those, i'll pick one up when i find the right one kind of deals... i keep my eyes open for domestic iron, but not too closely. as you so cleverly noticed, i am spacially challenged. 8^)
--r
--r
- mark1122
- Keep twisting it
Re: some progress.
25 Mar 2007 23:48
Thanks sol.once again your doing a greate job.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- solomrus
- solomrus
Re: some progress.
23 Apr 2007 13:57
whelp.
i ended up just having a custom sprocket made for me. it's working out really well.
a little clearancing on the inside of the stock sprocket cover, or i can just use the pmfr clutch plate that i have. haven't decided for sure yet on this.
i just ordered the z1000 top clamp that i am planning to use with the conversion. it will allow me to use risers from tag or renthal to mount up some fat bars. checking on those now, as well. i think that this upper clamp might also offer me some other options to mount my headlamp as well. i've been vacillating on how best to do this part.
i have a weekend by myself coming up. so, i can dedicate some good solid time to my bike. i have some work to get out of the way for my customers, but i think i should be able to come up with several contiguous hours to put into this.
it's *very* close to moving under it's own power.
--r
--r
