petcock 78 kz650 b2
- bobbycanuck
petcock 78 kz650 b2
12 Aug 2006 13:13
I have a 78 kz650 b2 that is complete and running but my petcock isn't working. When I originally took this bike apart I tried to drain the tank and noticed that no gas was coming out( I had it set to prime and previously the bike had not been running). So I am trying to find a petcock or a rebuild kit for the kz 650 and I've had no luck with the dealers or the recyclers in my area.
Thanks
bobby canuck
Thanks
bobby canuck
- rstnick
Re: petcock 78 kz650 b2
23 Aug 2006 19:07
Welcome to KZR.
Ebay can be a source, but you may just get another malfunctioning petcock. Z1enterprises or other parts dealers (links at the bottem right of the page) have rebuild kits available too. Although many have tried rebuilding and still had problems. Try a search in the Archives, as petcocks have been discussed many times.
I was lucky with mine (it was leaking). I just replaced the rubber disk behind the lever, the one with the 4 holes in it, and that solved my problem. Others just replaced theirs with a Pingle unit.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- OKC_Kent
24 Aug 2006 07:34
The easiest and least expensive in the long run is to buy an adapter plate and inexpensive on/off/reserve petcock from Z1Enterprises. You will need to block off a vacuum port on carb #2 with a rubber cap.
Read this:
www.z1enterprises.com/reference/petcock.aspx
Read this:
Cashion, OK
78 KZ650 B2 85,000+ miles
