Hello from Chattanooga, Tennessee
  • Crushing
  • Crushing's Avatar Topic Author
07 Oct 2026 08:03
#928296
Hope all are well and thank you for adding me to this forum. I have been a long time reader of this forum but have made the decision to finally join as I am recommissioning an 81 CSR after sitting in storage for 23 years.
I am currently in school for motorcycle and boat mechanics but have been turning wrenches since I was a child. I look forward to contributing as much as I can to this community.
Thanks,
Steve (Crushing)
The following user(s) said Thank You: z250b1
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: Hello from Chattanooga, Tennessee
07 Oct 2026 18:16
#928308
Welcome Steve
Lots of KZ help here
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
08 Oct 2026 00:01
#928313
Hi Steve, welcome from the UK
  • Mcdroid
  • Mcdroid's Avatar
  • Away
  • Gone Kwackers
08 Oct 2026 01:52
#928319
Welcome to KZRider, Steve.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • TexasKZ
  • TexasKZ's Avatar
08 Oct 2026 06:42
#928326
Welcome aboard.
if you have been lurking here for a bit, you know we need pictures.
  • Crushing
08 Oct 2026 09:35
#928335
 Here is her current state as I am going through issues with a broken cam cap. Rebuilding the forks and fixing the cam issue is all that is left. I will post more as I go.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
08 Oct 2026 09:54
#928336
You might want to look for someone who can weld that cap (once bolted down, where it’s broken is a low stress area) the caps are matched to the head so swopping one will open a world of challenges (ask me how I know!!) if you go the welding route it needs to be torqued down with the cam and bearings in place but valves removed during welding and allowed to cool fully before unbolting
  • Crushing
08 Oct 2026 10:35
#928338
Thanks for the info. I was wondering if it could be welded. I have another head and was trying to decided to swap the cap or replace the head. I will look into it and see if I can find someone who can weld it up. I do agree that would be the best route.
  • TexasKZ
  • TexasKZ's Avatar
08 Oct 2026 17:58
#928343
Thanks for the pics. If you click the Insert All button before posting the message, the pictures will show up full sized in the discussion thread.
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
09 Oct 2026 03:26
#928357
Welcome.  Wish you luck with the cam cap project.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
  • Crushing
09 Oct 2026 04:30
#928363
Thank you for the info.
  • v.f.
  • v.f.'s Avatar
09 Oct 2026 08:28
#928378
You could install different caps, but you would have to restore the camshaft bore alignment. This is done using a special reamer or a line-boring bar. The cap might warp after welding—even if bolted down with the camshaft clamped in place—meaning you would end up having to take the cylinder head to a machine shop. I’ve had the camshaft bore alignment restored on two cylinder heads. First, you check the camshaft for runout using a dial indicator on V-blocks; if the shaft is straight but still doesn't rotate smoothly in the head, then it’s time to take the head to a shop. Some automotive camshafts share the same diameter as the Kawasaki camshaft. But, of course, that’s up to you.
The following user(s) said Thank You: sf4t7, Crushing
