Hello from Chattanooga, Tennessee
- Crushing
07 Oct 2026 08:03
Hope all are well and thank you for adding me to this forum. I have been a long time reader of this forum but have made the decision to finally join as I am recommissioning an 81 CSR after sitting in storage for 23 years.
I am currently in school for motorcycle and boat mechanics but have been turning wrenches since I was a child. I look forward to contributing as much as I can to this community.
Thanks,
Steve (Crushing)
Thanks,
Steve (Crushing)
The following user(s) said Thank You: z250b1
Re: Hello from Chattanooga, Tennessee
07 Oct 2026 18:16
Welcome Steve
Lots of KZ help here
08 Oct 2026 00:01
Hi Steve, welcome from the UK
- Mcdroid
- Gone Kwackers
08 Oct 2026 01:52
Welcome to KZRider, Steve.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
08 Oct 2026 06:42
Welcome aboard.
if you have been lurking here for a bit, you know we need pictures.
- Crushing
08 Oct 2026 09:35
Here is her current state as I am going through issues with a broken cam cap. Rebuilding the forks and fixing the cam issue is all that is left. I will post more as I go.
08 Oct 2026 09:54
You might want to look for someone who can weld that cap (once bolted down, where it’s broken is a low stress area) the caps are matched to the head so swopping one will open a world of challenges (ask me how I know!!) if you go the welding route it needs to be torqued down with the cam and bearings in place but valves removed during welding and allowed to cool fully before unbolting
- Crushing
08 Oct 2026 10:35
Thanks for the info. I was wondering if it could be welded. I have another head and was trying to decided to swap the cap or replace the head. I will look into it and see if I can find someone who can weld it up. I do agree that would be the best route.
08 Oct 2026 17:58
Thanks for the pics. If you click the Insert All button before posting the message, the pictures will show up full sized in the discussion thread.
- slmjim+Z1BEBE
09 Oct 2026 03:26
Welcome. Wish you luck with the cam cap project.
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- Crushing
- v.f.
09 Oct 2026 08:28
You could install different caps, but you would have to restore the camshaft bore alignment. This is done using a special reamer or a line-boring bar. The cap might warp after welding—even if bolted down with the camshaft clamped in place—meaning you would end up having to take the cylinder head to a machine shop. I’ve had the camshaft bore alignment restored on two cylinder heads. First, you check the camshaft for runout using a dial indicator on V-blocks; if the shaft is straight but still doesn't rotate smoothly in the head, then it’s time to take the head to a shop. Some automotive camshafts share the same diameter as the Kawasaki camshaft. But, of course, that’s up to you.
The following user(s) said Thank You: sf4t7, Crushing
