Hello from Sydney Australia
- danscandar
- 1978 KZ650B Restoration
26 Aug 2026 13:49 - 26 Aug 2026 13:50
Hi All,
Working on my first restoration project, I'm battling my way through a full ground-up restoration of a 1978KZ650B and KZ650C. I've been plodding away for the last couple of years on this project, and I've nearly finished a full engine rebuild and rolling frame, and now it's time to get this thing fully operational.
Nice to meat you all
Last edit: 26 Aug 2026 13:50 by danscandar.
The following user(s) said Thank You: Mcdroid, z250b1
- Mcdroid
- Gone Kwackers
Re: Hello from Sydney Australia
26 Aug 2026 14:27
Welcome danscandar, welcome to KZRider. Thanks for the photo.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- gd4now
- Denco where did you go?
26 Aug 2026 14:45
Welcome to the fun! In the pic you posted it appears that the head has been installed in reverse than what it should be. At least to my old eyes I see the intake on the front of the head?
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
The following user(s) said Thank You: !Seymore
- kimchella
27 Aug 2026 13:37
Welcome danscandar from across the ditch, another KZ650 owner.
Rich.
NZ.
Rich.
NZ.
KZ650B1 frame number 225
New Zealand
New Zealand
- rstnick
30 Aug 2026 17:08
Welcome Dan.
Nice project.
I believe gd4now's eyes are correct.
Some reverse engineering going on.
Nice project.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- Injected
30 Aug 2026 17:47 - 30 Aug 2026 17:48
Welcome,
You do realize that the bike you posted the picture of has a 1979 model year frame?
The double foot peg bolts were introduced after the 1978 model year, so that makes it either a '79 B3 or '80 B4.
You can double check the neck VIN to find out. You might also want to verify your C model as well.
You can search out all Z/KZ650 info on this web site :
www.jarlef.no/Kawasaki/Series/Z/650/z650b.htm
1978 KZ650B2 modified project
Last edit: 30 Aug 2026 17:48 by Injected. Reason: more info
31 Aug 2026 00:02
Is this the old confusion about "model year" vs "build date" vs "1st registration"
- Injected
31 Aug 2026 05:46 - 31 Aug 2026 05:54Paperwork varies by country, some frames came with head decals and some did not.Is this the old confusion about "model year" vs "build date" vs "1st registration"
Here in Canada the VIN stamping on the frame is what they register it under and that only specifies the model, not the year. The head decal will have the build date but that does not dictate the registration model year. You would get the model year thru the frame serial number, as nowhere in our system do we document engine numbers at all. First registration here is done using the dealer import paperwork when the bike is purchased then tracked every time the bike changes ownership.
That web site I keep referencing is a invaluable knowledge base for the 650's. I have copied all the pages just in case it ever goes offline for good.
Last edit: 31 Aug 2026 05:54 by Injected. Reason: more info
The following user(s) said Thank You: rstnick
