K&N Pod filters with outer exhaust baffle removed
- Jordan.james151@gmail.com
10 May 2026 17:29
I am new to motorcycle riding. I bought my 79 kz650 from someone I used to work with. He gave me the pods and the airbox boots he was going to put on. This bike needed some work. I have not found the sweet spot for tuning this. I have tried looking for many solutions but have no came up with any. My mid and high rpm range are good, im just having trouble with idle. Does anyone know where I can get good carb holders with vacuum ports? Also, does anyone know how to tune these? Any and all help is greatly appreciated.
- kevski
Re: K&N Pod filters with outer exhaust baffle removed
11 May 2026 07:46
If cheap pods they will probably block idle circuit air jets, you will need air corrector jets to stop off idle stumbling and improve low end running, chances are with a bike hitting 50 years old the stock jetting is not in the carbs so will possibly need going through and checking.
11 May 2026 09:30
I believe im up to 120 with main and 20 with pilot jet. Could be one size up. I am running k&N pod filters which are not cheap. I do have cheap boots and was thinking last night about using threaded brass petcock so the nipple doesnt keep coming off and provides me a better seal. Im fighting with alot of issues with my bike right now. I just replaced the starter clutch 2 days ago. Im getting hanging idle and when idle drops to 1k, it likes to die.
- Injected
15 May 2026 17:30
Your main jet is massive for a stock 650 with only pods and what looks like a stock exhaust (avatar pic)
You need to drop the mains to #110 and put the pilots back to #15's then see if that helps. Your way too rich at #120/20 and it sounds like your sucking air in (hanging idle) so you need to find the leak path.
1978 KZ650B2 modified project
15 May 2026 17:59
It is a stock exhaust but I cut the very outside baffle out. It seemed to run way better with the pod filters off. Also. I raised my needle position up 1 notch.
- Injected
16 May 2026 07:34 - 16 May 2026 07:37Lower the needle back down, way too much fuel. My recommendation of #110 main is for the altered exhaust, that size jet works with pods/4 into1 and its a starting point.It is a stock exhaust but I cut the very outside baffle out. It seemed to run way better with the pod filters off. Also. I raised my needle position up 1 notch.
If you check your plugs they are probably black.
Even if your running velocity stacks and a straight thru exhaust you still may be rich at your jetting selection.
Last edit: 16 May 2026 07:37 by Injected. Reason: more info
16 May 2026 09:01
I checked the plugs. The outside ring is black, but the inside where the spark is, is almost white. I have 4 separate pods. I am adjusting valves as 2 of them are out of spec.
