Kick start works better than electric start on my '76 KZ750
  • HTBeedz
  • HTBeedz's Avatar Topic Author
04 May 2026 10:21
#923643
Does anyone have info on wiredgeorge’s coil mod? The site link is dead and there’s not much details here in the following comments. Thanks in advance
  • kimchella
  • kimchella's Avatar
Re: Kick start works better than electric start on my '76 KZ750
04 May 2026 12:41
#923645
Hi, here is his website and info on the conversion
Rich.
wgcarbs.com/index.php/14-sample-data-articles/89-coils
KZ650B1 frame number 225
  • zed1015
  • zed1015's Avatar
04 May 2026 12:49
#923646
The "mod" is to fit a relay into the ignition circuit so that the coils get 12v direct from the battery .
It is not needed if all your harnesses wiring connections and switch contacts etc are maintained and contacting as they should.
I've built hundreds of Zeds and never needed it..
It's just introducing an additional possible cause of failure into the system.
  • Nessism
  • Nessism's Avatar
04 May 2026 14:41
#923653
Agree.
I added it to one of my bikes some years ago, but hated all the clutter.  Removed it and cleaned the harness connectors instead.
And speaking of cleaning connectors, it's not always easy, particularly with female spade connectors and the like.  I wonder if media blasting with soda would be reasonable?  Easy to clean out when done, anyway.  Just thinking out loud...
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
  • H1Vindicator
  • H1Vindicator's Avatar
05 May 2026 05:30
#923681
just in case. make sure the battery is good. do a load test.
  • asphalt900
  • asphalt900's Avatar
05 May 2026 06:05
#923683
I'm with Ness and Zed on this often discussed topic. This "mod" generally is to mask dirty/corroded connections/broken wire splicing within the harness or switch contacts. If this is required for it to run then it would be safe to say all the all the other connections share the same issues, voltage drops wherever terminals are plugged into each other. Check the fuse holder blades, Right Hand ON/OFF/ON switch and Ignition switch first. Other internal wiring is a bit harder. Those RH "kill" switches come apart, photo of what they look like.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
05 May 2026 06:27 - 05 May 2026 06:35
#923685
Clay I'm not sure if you have read the "rational" in my old post I posted the link to ? I don't disagree that the "by-pass" is "masking other issues" however the main difference with the coils is that they need the maximum available voltage when the system voltage is at it's lowest (9.5 - 10v during cranking). You can't beat the "aging process" and as not just the contact surfaces but also the contact between the actual cable and connector are effected it all adds up. 0.2v here and 0.3v there will not impact on systems designed to operate at 12v when system voltage is around 13.5v when running. The difference with the coil circuit is that when you add up all those 0.2 and 0.3v drops cumulatively across all the connection points in the ignition circuit you could be as much as 1.5v or more down at the coils (now you are down to 8v when cranking) In a perfect world you could trim back all the wires to clean copper and replace crimp connectors which would get you back to "as new" however that is a significant task (especially for non electricians) therefore the "by-pass" is a pragmatic 30 minute solution to a weak spark and hard starting if everything else is working as it should
Back in the day it was common for vehicles to run 6v coils with a ballast resistor - during cranking a "by-pass" wire from the starter solenoid went directly to the coil by-passing the ballast resistor to give the best possible spark during cranking
Last edit: 05 May 2026 06:35 by Wookie58.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
05 May 2026 07:09 - 05 May 2026 07:10
#923686
Agree.
Only my opinion Ed but if you are going to that much trouble you would be better to replace the terminals. Blasting will remove the plating and won't resolve the lack of "spring tension" that occurs over time. If you want to go a step further you can do as I did on my build, all the cable ends are "sealed" with solder before fitting the crimp terminals (this stops moisture getting between the strands of copper and rotting the cables)
Last edit: 05 May 2026 07:10 by Wookie58.
  • Kelly E
  • Kelly E's Avatar
  • Away
  • Never Give Up. Never Surrender
05 May 2026 09:34
#923691
Agree.
I hold a dirty connector in rag(wear gloves) and spray into it with foaming battery terminal cleaner. Let it soak a couple minutes and clean out with non-clorinated brake cleaner. Then blow it dry with the air nozzle.
The metal bits come out shiny clean and so does the plastic connector body.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
The following user(s) said Thank You: H1Vindicator
  • ckahleer
  • ckahleer's Avatar
05 May 2026 10:44
#923696
I added a relay to my KZ305 a few years ago. So far it has been working fine. It is the quick and easy fix. but I am concerned about adding another possible failure point to the bike. I wired it in a way the relay could be bypassed in the event of a road side repair.
I agree with Wookie, on old bikes, cleaning switch contacts and connectors is not enough. To reduce voltage drop, all connectors in that circuit should also be replaced with quality Japanese or mil-spec connectors, basically rebuilding that section of the wiring harness.
1997 ZL600
94 KE100
82 KZ305
74 TC185
  • H1Vindicator
06 May 2026 05:55 - 06 May 2026 05:58
#923726
Thanks. I spray brake cleaner. then reconnect/disconnect the terminals several times. to clean up the surfaces. your way may be my new way. ha ha.
ps: never got around to getting de-oxit or whatever it's called. I've seen the crc stuff but never bothered to get it .
Last edit: 06 May 2026 05:58 by H1Vindicator.
