Gearbox wont gear 2345 any help?
  • Saioro
  • Saioro's Avatar Topic Author
03 Feb 2026 07:35 - 04 Feb 2026 18:34
#921175
I am Italian -78-from venice region
My first Kawa H1 1970 then sold it in 75 to buy Z 1 B 900 whic I still have it but bee sitting for a while.
Going to refurbish in some parts so guess I need some help from members
Problem I am facing now gearbox ( wont engage 2-3-4-5
Anyone can suggest ….
One million thanks
Lucio
nyone outhere had the gear box  not engaging second to fifth gears, what can be done
Thanks
Last edit: 04 Feb 2026 18:34 by KZQ.
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: Gearbox wont gear 2345 any help?
04 Feb 2026 18:36
#921227
Hello Lucio,
Welcome to KZRider !
I believe that what you're describing is called Kawasaki's "Neutral Finder". It prevents shifting to second unless the bike is traveling fast enough.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
The following user(s) said Thank You: StreetfighterKz, MFP-Joe, SWest, Wookie58
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
04 Feb 2026 23:51
#921229
Welcome from the UK Lucio
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
05 Feb 2026 03:20 - 06 Feb 2026 02:26
#921231
   The 'neutral finder' is a set of 3 ball bearings that move in grooves within the transmission by centrifugal force.  It prevents selecting 2nd. gear when the countershaft is stationary.  At least one of the three balls will be in a position to lock out 2nd. gear when at a stop, yet find neutral or select 1st. gear very easily.
   Assuming the drive chain is installed on your bike and the motor is stopped, place the bike on the centerstand, or get the rear wheel off the ground securely by some other means.  With the gearbox in neutral, spin the rear wheel by hand as fast as you can.  Move the shift lever up to 2nd. while the wheel is spinning fast.  Second gear should engage.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
Last edit: 06 Feb 2026 02:26 by slmjim+Z1BEBE.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
05 Feb 2026 06:49
#921232
I am going to hazard a guess here that since Lucio has owned his Z1 for 50 years he is probably familiar with the "neutral finder" function. Could it be that this mechanism is faulty after standing for so many years (ball bearings seized etc) ?
  • zed1015
  • zed1015's Avatar
05 Feb 2026 09:27
#921241
If that's the case then one or two balls could be gummed with old oil which would prevent them from moving outwards .
This wouldn't last long though once hot oil circulates..
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
05 Feb 2026 10:38
#921244
He stated it has been sitting for some time. I might suggest since the netural finder is a Kawasaki only thing he may not of been aware to begin with and if it has sat for a long period of time he may well have forgot.
This may help him to relearn what it does.
www.slashgear.com/1939820/kawasaki-motor...r-bikes-unique-tech/
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • sf4t7
  • sf4t7's Avatar
05 Feb 2026 15:16
#921257
Makes sense. After my Z1  sat for longer than it should have, I had forgotten about the neutral feature.  Then had an "oh yeah" moment!
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
