FIRST POST Valve Timing - Z1000J and Z1000K
- JTBS
24 Dec 2025 23:49 - 25 Dec 2025 05:17
I have been asked to fit some Z1000J cams into a Z1000K engine. I wish to dial them in accurately in using slotted cam wheels, can anyone supply me with the opening/closing figures for inlet and exhaust cams for both J and K engines please so that I can calculate the lobe centre figures. The manual that we have for the engine does not supply any information other than setting up using the standard procedure.
Regards,
Bill S
Regards,
Bill S
Last edit: 25 Dec 2025 05:17 by Street Fighter LTD.
- zed1015
Re: FIRST POST Valve Timing - Z1000J and Z1000K
25 Dec 2025 05:49 - 25 Dec 2025 05:50
The stock lobe centre cam timing figure for all the 900 through 1100 8 valve aircooled fours is 110 degrees regardless of cam profile and lift etc so there's no real need to know the actual opening and closing figures of the individual models.
Last edit: 25 Dec 2025 05:50 by zed1015.
The following user(s) said Thank You: KZQ, asphalt900, Wookie58
- gd4now
- Denco where did you go?
25 Dec 2025 08:24
There is a manual located in the filebase that has the info you are seeking.
kzrider.com/filebase-alias?view=download...vice-manual&catid=20
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
The following user(s) said Thank You: KZQ, Wookie58, JTBS
- KZQ
- Administrator
25 Dec 2025 08:39 - 25 Dec 2025 08:39
Welcome to KZR Bill S,
As you have read above, you need to just ask.
Thanks
Bill/KZQ
Thanks
Bill/KZQ
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
Last edit: 25 Dec 2025 08:39 by KZQ.
- JTBS
27 Dec 2025 00:59 - 27 Dec 2025 11:38
Thanks for the responses, especially the manual download link, the required figures are:
Z1000J
35/65-280 LC 105
68/32-280 LC 108
Z1000K
30/60-270 LC 105
63/27-270 LC 108
Z1000J
35/65-280 LC 105
68/32-280 LC 108
Z1000K
30/60-270 LC 105
63/27-270 LC 108
Last edit: 27 Dec 2025 11:38 by JTBS. Reason: Typo
27 Dec 2025 10:50There seems to be a typographical error in the K/M exhaust numbers. I am pretty sure that 63 + 180 + 27 = 270.Thanks for the responses, especially the manual download link, the required figures are:
Z1000J
35/65-280 LC 105
68/32-280 LC 108
Z1000K
30/60-270 LC 105
63/27-280 LC 108
The following user(s) said Thank You: JTBS
28 Dec 2025 10:32Rob is the 110 degrees an optimised setting to compensate for manufacturing tolerances in the factory TDC mark ? (just asking as it seems to differ from the manual ?)The stock lobe centre cam timing figure for all the 900 through 1100 8 valve aircooled fours is 110 degrees regardless of cam profile and lift etc so there's no real need to know the actual opening and closing figures of the individual models.
