New member intro '77 kz650 starter clutch
- garyS
15 Nov 2025 06:59
Hi all... new member here with my first own kz. I rode my brother's '76 kz650 45 years ago and this '77 popped up on the market so I had to buy it even tho I probably won't keep it with my '79gs1k. It looks to be in good shape and "only needed a little carb tuning. I replaced the starter solenoid and cleaned the starter and almost done with the carbs. I'll search and post the technical sections but instructions here say introduce and ask a question.. so does that look like the correct spring for the fill side of the accel pump? And starter clutch mine was making a racket when the motor shut down. I suspected it was always engaged but with starter out the gear freespins one way (seems right). So when this motor shuts down does the starter briefly come in for a puff of spin? I know that sounds crazy but when my zrx shuts down I hear a brief spin down.
Re: New member intro '77 kz650 starter clutch
16 Nov 2025 09:35NO - any time the motor drives the starter you risk exploding the commutator in the starter motor. It's possible if the clutch basket and starter clutch cush-drive rubbers are worn that there may be some "chatter" when shutting down. I suspect what you hear on the ZRX is the alternator spinning down (I don't know if it has a "freewheel" drive set up)Hi all... new member here with my first own kz. I rode my brother's '76 kz650 45 years ago and this '77 popped up on the market so I had to buy it even tho I probably won't keep it with my '79gs1k. It looks to be in good shape and "only needed a little carb tuning. I replaced the starter solenoid and cleaned the starter and almost done with the carbs. I'll search and post the technical sections but instructions here say introduce and ask a question.. so does that look like the correct spring for the fill side of the accel pump? And starter clutch mine was making a racket when the motor shut down. I suspected it was always engaged but with starter out the gear freespins one way (seems right). So when this motor shuts down does the starter briefly come in for a puff of spin? I know that sounds crazy but when my zrx shuts down I hear a brief spin down.
- Bobf
- KZ1000A3A
16 Nov 2025 19:16 - 16 Nov 2025 19:22What Wookie saidHi all... new member here with my first own kz. I rode my brother's '76 kz650 45 years ago and this '77 popped up on the market so I had to buy it even tho I probably won't keep it with my '79gs1k. It looks to be in good shape and "only needed a little carb tuning. I replaced the starter solenoid and cleaned the starter and almost done with the carbs. I'll search and post the technical sections but instructions here say introduce and ask a question.. so does that look like the correct spring for the fill side of the accel pump? And starter clutch mine was making a racket when the motor shut down. I suspected it was always engaged but with starter out the gear freespins one way (seems right). So when this motor shuts down does the starter briefly come in for a puff of spin? I know that sounds crazy but when my zrx shuts down I hear a brief spin down.
Spring looks right.
Here's a diagram link for the secondary shaft upon which the starter clutch resides. If your starter is starting the engine, the starter-clutch is probably working okay. If you have to replace any of these items, it is a PITA as you likely will need to take the engine out and split the cases to get to the inner parts. Not all of them are accessible from the outside. The KZ650s and 750s with same configuration (Also 650/750 Yamahas of the same era) drive the crank from a jack-shaft instead of the end of the crank like z-1, KZ900 and 1000s.
www.kawasaki.com/en-us/owner-center/parts/143079/1979/KZ650-C3
Hope this helps!
Bobf
EKKAWI
1976 KZ400D, 1977 KZ1000A1, 1976 KH400, 1979 XS400, 1980 KZ550A, 1980 KZ750E, 1983 GPZ550,1979 KZ1000B LTD, 1986 ZG1000 Concours,1982 XS650 Turbo,KZ1000C, KZ1000P,1978 KZ650C (×2),2003 BMW R1150RT
2014 BMW R1200RT (Current ride)
1971 Norton 750 Commando
1979 KZ1000A3A MKII (Present project)
Last edit: 16 Nov 2025 19:22 by Bobf. Reason: Removed redundant photos from OP. Added comment on spring.
- Warren3200gt
17 Nov 2025 00:04
Having restored about 20 650's over the years here's my 2 peneth worth.
No, the starter shouldn't and can't engage on shut down.
"IF" you decide to replace it ensure you replace the whole unit and starter gear NOT just use the springs and rollers repair "kit" unless you want to do it again in short order.
The whole job can easily but fiddlely done from underneath without removing the engine.
Remove the sump pan and clutch basket plus a few retaining plates and the shaft can slide out allowing removal of both the starter clutch and gear. Your hardest job is the clutch basket hub nut which is torque to 130 ftlb.
Before removal check the primary chain free play. The service limit is 27mm.
Heres a picture of a new and worn starter gear for reference.
The following user(s) said Thank You: Wookie58, Bobf, kimchella
- Bobf
- KZ1000A3A
17 Nov 2025 19:50Having restored about 20 650's over the years here's my 2 peneth worth.
Much thanks for your insight!!! Learn something new every time I come on this forum. Now I feel like finding a used KZ650 "....starter doesn't work....." to try this out! I wasn't as innovative back in the day and could have saved much time if I'd only..... 20/20 hind sight!!
EKKAWI
18 Nov 2025 07:27
That photo showing a NEW vs USED starter clutch gear has been posted here countless times. Thing is, I've never seen a NEW gear, other than when it came out of the OEM packaging. After a short time in the vehicle, they all look like the USED gear, and most function just fine.
- Warren3200gt
18 Nov 2025 08:00The starter clutch and starter gear wear together as a pair. Yes, you can just replace the starter clutch but a worn starter gear will prematurely wear your new starter clutch.That photo showing a NEW vs USED starter clutch gear has been posted here countless times. Thing is, I've never seen a NEW gear, other than when it came out of the OEM packaging. After a short time in the vehicle, they all look like the USED gear, and most function just fine.
Much the same as a new final drive chain on worn sprockets will reduce chain life and vice versa. They need to be replaced as a set.
It all depends if you want to do the job properly or on the cheap at the expense of longevity.
- rstnick
18 Nov 2025 17:05
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
