Thanks for letting me join the forum I'm DustyDeck and I have a KZ650 with MODS
  • dustydeck
  • dustydeck's Avatar Topic Author
17 Sep 2025 11:48 - 17 Sep 2025 15:11
#917302
My KZ650 has the GPZ750 oil cooler and oil pan along with 26 mm Mikuni smoothbore carbs, K&N pods and Vance and Hines 4 into one. Inside my KZ650 it has a Ninja 600 6 speed transmission with the Dyna coils and ignition. I'm having trouble dialing in the carbs but I'm getting close 117.5 mains, 15 pilots and the jet needles are in the 3rd position.  The carbs are backfiring. I'm guessing its a lean miss. I plan to check the float hight and dropping the needle jets to the 2 position. Any sugestions would be appreciated. Thanks to everyone
Last edit: 17 Sep 2025 15:11 by Street Fighter LTD.
The following user(s) said Thank You: KZQ, ThatGPzGuy, Nessism, MFP-Joe
  • Nessism
  • Nessism's Avatar
Re: Thanks for letting me join the forum I'm DustyDeck and I have a KZ650 with MODS
17 Sep 2025 16:28
#917307
NICE bike.  Welcome!
Those carbs are most likely VM24's.  Not VM26.  And NOT smoothbores, which start at VM29.
You can tell because 26's have a smooth carb body on the outside, and 22/24's have ribs, like yours.
The following user(s) said Thank You: dustydeck
  • 82KZ305Belt
  • 82KZ305Belt's Avatar
17 Sep 2025 17:28
#917312
That's beautiful. That's what mine want to look like when they grow up.  Welcome.
81 KZ650 CSR
77 KZ650B (not in my paws yet)
82 KZ305 CSR
  • dustydeck
17 Sep 2025 17:55
#917314
Thanks that will help alot. I have a set of VM 26s and 24s.
  • kimchella
  • kimchella's Avatar
17 Sep 2025 18:38 - 18 Sep 2025 11:04
#917315
Welcome to the fun from New Zealand. Nice bike. A photo of my 650 ready for summer.
KZ650B1 frame number 225
New Zealand
Last edit: 18 Sep 2025 11:04 by Street Fighter LTD.
  • dustydeck
17 Sep 2025 19:50
#917317
Thanks, hah, the beast has growing pains...
  • dustydeck
17 Sep 2025 19:53
#917319
You have a beautiful example of a stock KZ650 , Precious
The following user(s) said Thank You: kimchella
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
17 Sep 2025 23:50
#917329
Welcome from the UK, great looking bike
  • MFP-Joe
  • MFP-Joe's Avatar
  • forever 18 when on my bike ...!
18 Sep 2025 00:02
#917330
Welcome also, a nice bike indeed!
Z1000 A1 1976
Z1000 A2 1977
Greetings, Joe
  • zed1015
  • zed1015's Avatar
18 Sep 2025 01:39 - 18 Sep 2025 01:56
#917334
When running without the stock air box you need to fit air corrector jets to cure the off idle lean spot, leave the pilot jet and needle position STOCK ( 4th groove from top) and just increase the main jet..
117.5 mains are miles too big..
For the vm24 you need to go up from 102.5 to 105 mains..
Last edit: 18 Sep 2025 01:56 by zed1015.
  • dustydeck
18 Sep 2025 13:59
#917353
I changed the main jets to 105s and dropped the jet needle position to 4 and it is running much better now. Thankyou. Just needs a good sync I think and I should have it. Maybe I will try the 102.5s but not yet till I've given it a little run. Thanks again
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
18 Sep 2025 15:34
#917355
You will still need Zed’s “air correctors” to avoid off idle flat spots
The following user(s) said Thank You: 82KZ305Belt
