New here from Canada
  • KrazyKZ200
  • KrazyKZ200's Avatar Topic Author
21 Jul 2025 21:29
#914928
            I just found a ‘77 kz200 for cheap, it’s essentially a bike in a box, I’m making arrangements to go pick it up in the next week or so.
I’m looking at cdi conversion and hydraulic disk brake conversion
after studying pictures of the front brake I think I have an off the shelf solution to gain hydraulic disc brake.
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
The following user(s) said Thank You: KrazyKZ200
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: New here from Canada
22 Jul 2025 19:41
#914977
Welcome from Canada!
A buddy had a KZ200.
I was surprised it had a cable activated front disk brake.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
23 Jul 2025 08:52
#914987
Nice find...I always wanted to fall into a KZ200.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • KrazyKZ200
24 Jul 2025 17:27
#915043
Mechanical disk brakes weren’t uncommon in Japanese motorcycles and small dune buggies
  • KrazyKZ200
26 Jul 2025 01:32
#915092
As soon as I pick this up, hopefully this weekend, I’ll be starting a project thread.
  • KrazyKZ200
04 Aug 2025 16:17
#915524
    Had to put off picking up the kz200 till the end of the month.
A friend recently crashed their ninja 250r and said if there are any parts that’ll work on the KZ I could have them for cheap, just before their bike got written off they bought a USD fork and triple tree conversion kit but didn’t get to install it.
Has anyone swapped stock ninja 250r front suspension onto a kz200? If the front suspension will fit, I’ll snag it and the swing arm which I’ll get a welder friend to add shock mounts to convert it to dual shock swing arm.
Im not sure which part of the forum I can load up with tech questions. I hope it’s ok here till I know the correct section.
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
05 Aug 2025 00:04
#915545
To be honest I doubt anything will fit without significant modification and machine work, unless you have access to the required machines or a buddy that is a machinist this will get very expensive real fast and there is still the possibility that it won't work. You would probably need to keep with the stock wheels as I doubt you can buy off-set sprockets which would lead to the need to adapt to the stock axles which would bring challenges with the speedo drive etc. In short just about everything would need custom mods to fit and work. I'm not saying it's not achievable but you need to go into the project with your "eyes open" so it doesn't end up on Ebay as an "unfinished project" good luck
  • KrazyKZ200
05 Aug 2025 13:24
#915576
Hey wookie thanks for the reply. Figured I’d ask here before tossing money out the window.
There’s precious little information on swapping parts for the KZ200. Unless you’re from Indonesia and similar countries, but the parts the donor bikes aren’t available in North America.
