First post Front Brake Rotor Sizing
- jackson_mitchell@outlook.com
18 Jun 2025 05:26 - 18 Jun 2025 08:03
Hi there, not sure if this is the right place to ask.
I’m looking for a front brake rotor for my bike.
It’s a 1984 KZ750 twin I replaced the front end with a 82 KZ750 twin csr.
Front callipers and rotors match each other but when I took it to get a safety inspection they found a tiny crack in the front rotor.
The rotor is 130mm ID and 280mm OD.
Looks identical to all other Kz rotors of the time but online I can only find 260mm OD or 270 OD rotors.
Does anyone know what this rotor could be off of?
I need to buy a replacement but EBay doesn’t seem to commonly list diameter just rotor thickness.
Last edit: 18 Jun 2025 08:03 by jackson_mitchell@outlook.com.
- zed1015
Re: First post Front Brake Rotor Sizing
18 Jun 2025 07:36
The 279 one will be correct if it's the same offset and bolt mount.
18 Jun 2025 08:14
My bad that was supposed to be 270mm rotor that I found. I still haven't found this 280mm rotor.
18 Jun 2025 10:39
There was a typo in my original question I've since edited. I could only find a 260mm rotor and 270mm rotor. I still need to find the 280mm rotor which would match what I have now.
18 Jun 2025 10:42
Sorry I had a typo in my original message that I've since corrected. I need a rotor that has an OD of 280mm and i have only been able to find ones that are 260 and 270mm.
- H1Vindicator
19 Jun 2025 08:31 - 19 Jun 2025 08:57
I replaced the front end with a 82 KZ750 twin csr.... Does anyone know what this rotor could be off of?
a pic would help. it's probably the 750csr disk. could be unique to the model. you'll need to verify but the 650csr and 1000csr may have had similar disks that are different than the 70s models. my original 1981 650csr disk measures 281mm (11-1/16"). the service limit is 4.5mm. the 82 is 5.5mm. the 750 is possibly thicker than the 650. the 1000 has a dual disk Fr brake. could be a smaller diameter. don't know. the 650/1000 csr disks have 8 rivets. some earlier disks are 9 rivet.
Last edit: 19 Jun 2025 08:57 by H1Vindicator.
19 Jun 2025 08:59
thanks for the response. I may have made a dumb decision and bought a 1999-2005 Kawasaki Vulcan 1500 Nomad front rotor. Inside Diameter is 130 Outside Diameter is 280 with a 7 bolt pattern 7mm thick. Sounds like it could work (possibly). its going to take a month to come in so I can come back and confirm if it works or not. Wish me luck.
- H1Vindicator
19 Jun 2025 09:33
is your current disk 4-bolt. with a mounting hub riveted onto it?
19 Jun 2025 12:06
You also need to be aware of the offset between the mounting surface and the disc. The wrong offset will prevent the disc and the caliper from lining up.
20 Jun 2025 10:46
It’s a 7 bolt disk. Hopefully this photo helps.
this rotors OD is 280mm but is sadly cracked. Still trying to see if I can find any replacement.
- Warren3200gt
20 Jun 2025 12:07 - 21 Jun 2025 07:53
Zpower UK. Will ship world wide or Google EBC MD4038 for supplier near you.
(EBC MD4038)
FRONT FITMENT = Z1000J3, Z1000R2, GPZ1100B2.
These are EBC discs, OD 280MM ID 130MM 7 HOLE MOUNTING.
www.z-power.co.uk/brake-disc-ebc-md4038
(EBC MD4038)
Last edit: 21 Jun 2025 07:53 by Warren3200gt.
- H1Vindicator
21 Jun 2025 06:01 - 22 Jun 2025 06:30that's not a 750m-csr front wheel or disk. check the wheel size. should be cast into it. single disk, could be from 750k twin. or 440 or 550, or 650 from the 80s. the 550c-ltd Fr wheel is 19 x 1.85.It’s a 7 bolt disk. Hopefully this photo helps.
Last edit: 22 Jun 2025 06:30 by H1Vindicator.
