First Post KZ200 '77 Speedo Replacement
- Coulson
06 Jun 2025 02:38 - 06 Jun 2025 05:17
Hi first time on here and have had a good look for this before posting so hopefully I don't embarrass myself... I have a KZ200 1977 and the speedos are a touch trashed. In fact the whole bike is rusted through so it's getting the full works. My question is that I am looking to replace a mechanical speedo gauge with another mechanical gauge and I understand the need to match ratios etc, and I could work out the k value using tyre circumference and distances travelled etc which is all very interesting learning and probably will do at some point for accuracy, however I have read several times that the K Value of the speedo should be in the bikes literature or written on the back of the speedo itself....
I have tha haynes, original workshop and owners manuals for the bike and it doesn't state it anywhere, again unless I am being stupid which is a distinct possibility. Also my gauges are unreadable on the back. There is some evidence of print there but nothing I can read. Does anyone have this figure or a speedo that states it?
Many thanks
Many thanks
Last edit: 06 Jun 2025 05:17 by Street Fighter LTD.
Re: First Post KZ200 '77 Speedo Replacement
06 Jun 2025 05:26
Welcome from Leicestershire
The following user(s) said Thank You: Coulson
- H1Vindicator
06 Jun 2025 09:39 - 06 Jun 2025 10:24
most Japanese speedometers are 2240 revs per mile. some of them are stamped on the back. mine says 2240 revs = 1 mile. using the 1978 kz200a diagrams. with a 17" wheel and 2.65 gearbox ratio. yours is probably a 2240 speedometer. ps: you might want to verify the year. a motorcycle mfg'd in 1977 could be a 78 model.
Last edit: 06 Jun 2025 10:24 by H1Vindicator.
