1977- kz750 - MISSING IGNITION KEY
- terickson
28 May 2025 17:09
Looking for information on getting/making a key for a 1977 KZ750
The bike was a Barnfind. Bought for $500
Cleaned up good.
Dont want to put more money into it unless I can get a key.
Whats the best process?
Any ideas
Cleaned up good.
Any ideas
Re: 1977- kz750 - MISSING IGNITION KEY
28 May 2025 18:14
Remove ignition lock, go to locksmith, get key made. I watched a guy do this for my old GS450, and he filed a key in less than 10 minutes.
29 May 2025 03:56
The above is the best solution but an alternative is to remove the ignition and replace it with one with a key.
29 May 2025 04:11
member rstnick can supply keys to lock number
The following user(s) said Thank You: ThatGPzGuy, Warren3200gt
- H1Vindicator
29 May 2025 07:33 - 29 May 2025 08:15a key is still needed for the seat lock and helmet lock if it has one. assuming they're all keyed the same and he doesn't have the key for those either.The above is the best solution but an alternative is to remove the ignition and replace it with one with a key.
To the op. the ignition switch may have a code stamped into it. either a locksmith or rstnick should be able to cut a key from that code. stock: the seat lock and helmet lock would have had matching codes. ps: in case it needs to be said. get a couple of spares. when I first learned to ride. I lost both keys during a move. no internet back then. so it was a pain.
ebaayy. KZ750B ignition switch with code
Last edit: 29 May 2025 08:15 by H1Vindicator.
- riturbo
29 May 2025 14:08
There's guys on ebay that will cut them to code also .
Kawasaki Replacement Keys by Code for sale | eBay
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
29 May 2025 14:57Maybe I'm just cynical in my old age but sending my key number and address to a stranger would make me nervous, there have been instances of dealer staff "cloning" keys on vehicles being serviced then selling the key and address some time laterThere's guys on ebay that will cut them to code also .
