Replacing the fuel line and vacuum lines
- RetroRipper
01 May 2025 10:31 - 01 May 2025 12:35
Hey guys I’m new the group. I have a 1976 kz400 with dual carbs. How do I run the fuel lines correctly? I’ve seen all sorts of info but I’m getting confused. There are 2 ports at the petcock, a fuel inlet in the middle of the carbs (fuel rail) and one inlet on each carb as well. How do I correctly set this up? TIA!
Last edit: 01 May 2025 12:35 by Street Fighter LTD.
Re: Replacing the fuel line and vacuum lines
01 May 2025 15:35 - 01 May 2025 15:38
That is interesting. According to the factory service manual, the petcock should have a single outlet. The hoses on the bottom of the bowls (#eight) are for drain or overflow. The ones on the sides (#5) are the bowl vents, and the fuel inlet in the center should be on the outside of the #2 carb (#11).
Last edit: 01 May 2025 15:38 by TexasKZ.
The following user(s) said Thank You: Scirocco, Gdizard
- gd4now
- Denco where did you go?
01 May 2025 16:22 - 01 May 2025 16:34
I do not know this for fact but the pic of his carbs look more like the carbs on the 77 version of the 400 than the earlier versions.
I would also state that 2 ports on the petcock does not mean it is a vacuum operated one. What if anything is stamped around the petcock lever?
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Last edit: 01 May 2025 16:34 by gd4now.
01 May 2025 18:42
Here is a parts diagram for the 1978 Kz400. They look like what you have.
www.partzilla.com/catalog/kawasaki/motor...uretor-assy-kz400-a2
01 May 2025 18:45 - 01 May 2025 18:49
I just took a closer look at the fsm pic above, and dang if it doesn't look like there is a spot for a fuel line between the carbs, in front of the balance screw, #12.
Last edit: 01 May 2025 18:49 by TexasKZ.
02 May 2025 13:26
The following user(s) said Thank You: gd4now, MFP-Joe
- RetroRipper
04 May 2025 18:02
Oh great. So I bought the wrong carbs is what you’re telling me……
I do need help with the throttle cables. One of them has so much slack but I’ve backed them all the way out already… help!!!
