81 kz305 pistons
- deegster19
81 kz305 pistons
18 Apr 2025 22:34
Hey everyone, this is my first post here. I recently got a 1981 kz305 that had been sitting for 20+ years in a shed. Long story short it ran and drove with simple maintenance, but severely lacked power. I eventually figured out it needed the valves to be redone bcuz of rust and carbon buildup on the seats, and i figured i might as well do the rings while I'm at it, and I had found a relatively cheap ring kit for it. When I went to take it apart, part of the piston in between the two compression rings just fell apart. The piston and cylinder walls also had scoring, and it is going to need new pistons. After a few hours of scouring I have come up with the conclusion that pistons for this bike are almost impossible to find. Does anyone have any ideas as to where I could get some at a reasonable price? What are my options here? Any help is greatly appreciated!
Re: 81 kz305 pistons
19 Apr 2025 16:48Hey everyone, this is my first post here. I recently got a 1981 kz305 that had been sitting for 20+ years in a shed. Long story short it ran and drove with simple maintenance, but severely lacked power. I eventually figured out it needed the valves to be redone bcuz of rust and carbon buildup on the seats, and i figured i might as well do the rings while I'm at it, and I had found a relatively cheap ring kit for it. When I went to take it apart, part of the piston in between the two compression rings just fell apart. The piston and cylinder walls also had scoring, and it is going to need new pistons. After a few hours of scouring I have come up with the conclusion that pistons for this bike are almost impossible to find. Does anyone have any ideas as to where I could get some at a reasonable price? What are my options here? Any help is greatly appreciated!
I feel for you 305 lovers, because it seems like there are constant engine problems with those bikes. And now, modern times, parts are quite scarce. Honestly, even if you fix the engine, based on reports I keep reading here, there is no guarantee that it will stay reliable. Don't feel bad about cutting bait, and parting that sucker out. Put the money gained into a newer and more reliable bike.
20 Apr 2025 08:21
GPZ305 pistions 1,00 mm oversize. Cyl. bore/hone size 62,00 mm.
www.scheuerlein-motorentechnik.de/motorr...n-kit-uebermass-1-00
- ckahleer
20 Apr 2025 08:48 - 20 Apr 2025 08:50
Or just maybe. What is center of hole to top on the stock piston?[attachment=176853]301c3395f87105da6bf0e50a7cae11a6[/attachment][attachment=176853 wrote: Screenshot 2025-04-20 11.37.38 AM.png[/attachment]Scirocco post=911523 userid=48181"]GPZ305 pistions 1,00 mm oversize. Cyl. bore/hone size 62,00 mm.
97 ZL600
94 VF750c
94 KE100
82 KZ305
94 VF750c
94 KE100
82 KZ305
Last edit: 20 Apr 2025 08:50 by ckahleer.
