Hello from Waterloo, Ontario
  • bonyt
  • bonyt's Avatar Topic Author
31 Mar 2025 17:05 - 31 Mar 2025 17:08
#910799
Hey All,
I just purchased a 79 KZ13 from the original owner. Bike has sat since 1990, engine was frozen, and no keys.
Otherwise the bike is complete including panels, fuel tank, tool kit, and owners manual. Mufflers do have some surface rust which hopefully will clean up.
Already got a set of replacement keys made up, and they work perfectly in ignition, tank and seat lock.
Also put the bike on the center stand with transmission in 5th gear, poured a 50/50 mix of acetone and ATF into the cylinders and let it soak overnight.
Sure enough after working the rear wheel in reverse then forward, I was able to rotate the wheel at least 2 rotations and she is definitely unfrozen now.
Really looking forward to restoring this bike, and asking lots of questions along the way.
Cheers
Last edit: 31 Mar 2025 17:08 by bonyt. Reason: modify text
  • sf4t7
  • sf4t7's Avatar
Re: Hello from Waterloo, Ontario
31 Mar 2025 17:29
#910801
Welcome to our crazy world!
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
  • Cra-z1
  • Cra-z1's Avatar
31 Mar 2025 18:16
#910802
Welcome, sounds like a great project.
We need photos
  • TexasKZ
  • TexasKZ's Avatar
31 Mar 2025 18:27
#910803
Welcome aboard! Looking forward to your resurrection thread.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
01 Apr 2025 03:24
#910814
Welcome to KZRider.  You'll be pleased to know that our site administrator (KZQ) knows quite a bit about KZ1300's
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
