Gasket
- Carb_1190
Gasket
22 Jan 2025 10:13
Hey y’all, new to this website, still learning how to post.
im rebuilding a 1982 kz750n spectre.
head and cylinders came back from the machine shop
getting ready to place gasket between crankcase and cylinders
trying to do research on to use rtv or no rtv.
and suggestions?
and suggestions?
Re: Gasket
23 Jan 2025 05:33
Welcome to KZRider
I moved your post here and your next post must be here as a real introduction to our members .
Tell us about your motorcycle interests and background
Re: Gasket
23 Jan 2025 08:09
Strongly suggest getting the factory Kawasaki manual for your bike. Inside, you will find guidance regarding things like where to apply gasket sealer. For my similar 750E, the manual highlights specific areas on both the base and head gaskets where sealer should be applied. The Filebase here has the chain drive 750 manual, but not the shaft.
- Injected
Re: Gasket
23 Jan 2025 08:11
Welcome.
Search "base gasket" on here.
You also might want to elaborate on you and your project bike, post a picture, etc.
1978 KZ650B2 modified project
- H1Vindicator
Re: Gasket
23 Jan 2025 09:45
get a KZ750 shaft manual. I don't recall ever seeing a pdf, so you're probably going to have to buy one.
The following user(s) said Thank You: Injected
- Injected
Re: Gasket
23 Jan 2025 10:01 - 23 Jan 2025 10:06100% on that, not on here to be downloaded. Pretty elusive on Ebay as well.get a KZ750 shaft manual. I don't recall ever seeing a pdf, so you're probably going to have to buy one.
I have a 750 Spectre engine on one of my bikes, so I just used a KZ750 manual which covers the GPZ750 (engine almost identical)
You would only ever need the "real" manual if you had to sort anything to do with the shaft drive case. I do remember adjusting the clutch rod was a whole different procedure as it is attached to the weird trans cover.
Last edit: 23 Jan 2025 10:06 by Injected. Reason: info
- KeylAmi!
- Engineer with ADHD
Re: Gasket
24 Jan 2025 04:07
I found a bit of info on the exact manual to use, from a kawasaki model identification pdf:
Hope this helps
Hope this helps
Current project:
'84 KZ700
'84 KZ700
- H1Vindicator
Re: Gasket
24 Jan 2025 06:02 - 24 Jan 2025 06:03
he can use any kz750 shaft manual. pretty sure. since the first manual is the same as his model year and subsequent manuals cover the 82. looks like it's going to cost $40-50 at the minimum.
Last edit: 24 Jan 2025 06:03 by H1Vindicator.
