Return to KzR after a long while.
  • StreetfighterKz
  • StreetfighterKz's Avatar Topic Author
17 Jan 2025 14:48
#907994
Hey all,
Some of the “old timers” may recognize my username from here and a few other forums. I used to be quite active from 2000-2015ish. But life and other things pulled me away from here.
Anyways, I’m back and have a few more rides than when I left.
‘76 Kz900 Strip-fighter (still moth-balled in the rafters)
’78 Kz1000 Streetfighter (now on it’s 4-5th version)
’83 Gpz750 Resto-mod
’79 Kz650 Resto-mod (current project)
’18 Z900RS (Daily rider)
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
The following user(s) said Thank You: sf4t7, SWest, Wookie58, kimchella
  • Mcdroid
  • Mcdroid's Avatar
  • Away
  • Gone Kwackers
Re: Return to KzR after a long while.
17 Jan 2025 14:52
#907995
Welcome back...and home.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • TexasKZ
  • TexasKZ's Avatar
17 Jan 2025 15:06
#907996
Welcome back!
Looks like those projects should keep you busy for a bit.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
17 Jan 2025 16:51
#907998
Back with a "bang" what a stable of projects :)
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
17 Jan 2025 17:55
#907999
Good to see you Buddy
To a Streetfighter
From a Street Fighter
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
18 Jan 2025 07:38 - 18 Jan 2025 07:56
#908011
Those who were infected with The Dreaded Z-Bug in the past will always be so.
  There is no known cure.
It's purposely undocumented & never spoken of in medical journals or legacy media for fear of causing panic within the un-biked masses & HD riders in particular.
   We see you've been self medicating while away by applying more & more Z-bikes.  Satisfying but, ultimately doomed to repetition, as The Dreaded Z-Bug always compels it's host to feed it with more & more Z-stuff.
     It doesn't even have to be hardware acquisition; those so inflicted are also driven to search out arcane bits of knowledge, such as the number of leaves on a Z1 horn bracket.  Or why, in the White Manual > Maintenance > Carburetors > Table 3, it says "Fuel Lever 32 +/- 1mm", when it's also correct that, under Maintenance > Carburetors > 'Fuel level measurement and adjustment', it clearly states "The gasoline level in the hose should come up to .10 ~ .18 inch (about 1/8 inc, or 2.5 ~ 4.5 mm) below the edge of the carburetor body."  How can both be correct?   Only those who are irrecoverably infected know...
   Such driven desire for obscure knowledge might cause 'normal' people to question their sanity.  But not us Dreaded Z-Bug hosts.  It can also cause arcane & otherwise-useless paragraphs like above to be typed.
  There is even one documented occurrence of a female spouse (who shall remain nameless) who was infected by proximity to her husband (who shall also remain neaneless) to ruin the fresh, bright-red war paint on her claws due to spending hours at a wire wheel, making tiny vintage parts aesthetically pleasing.
  Try as we might, resistance is futile.
   Welcome back!
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
Last edit: 18 Jan 2025 07:56 by slmjim+Z1BEBE. Reason: Not enuff stoopid.
  • howardhb
  • howardhb's Avatar
  • God, I trust
18 Jan 2025 12:46
#908018
Zee infected, to be sure!
...it has to be '(Z)actly, between 2.5 ~ 4.5 mm
Welcome back!
'81 GPz 550 D1
'82 Yamaha YB100 Fizzie
The following user(s) said Thank You: slmjim+Z1BEBE
  • riturbo
  • riturbo's Avatar
19 Jan 2025 17:49
#908058
Good to see you back.
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
  • Injected
  • Injected's Avatar
20 Jan 2025 08:52
#908069
Welcome back.
Aware of your projects from the Z650 forum in the UK.
1978 KZ650B2 modified project
