Electrical
- jstry11
Electrical
23 Dec 2024 20:41
I'm in search for the simplest wiring diagram using the OEM regulator and IC igniter to get spark at the plugs. For the life of me I can't figure out the coil wiring. Any help or guidance will be greatly appreciated
1982 KZ 550
1982 KZ 550
82 KZ 550
Re: Electrical
24 Dec 2024 05:58
The following user(s) said Thank You: jstry11
Re: Electrical
24 Dec 2024 06:00
You should download everything you think you might ever need from his website, because one day it will all disappear without warning.
s3.amazonaws.com/gpzweb/index.html#home
The following user(s) said Thank You: slmjim+Z1BEBE, F64
- gd4now
- Denco where did you go?
Re: Electrical
24 Dec 2024 07:17
I do not currently have a color wiring diagram for the 82 550, I have several in black and white which I for some reason have problems with that the color ones do not give me.I do have a pic of a 650 B1 showing just what you are asking for and have attached it below. Keep in mind there are some major changes (points, excited field alternator etc) but it does show the paths.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- H1Vindicator
Re: Electrical
24 Dec 2024 10:02 - 25 Dec 2024 08:24
the posted gpz550 wiring diagram is probably from the bare bones for mattylight topic. if it's still available. I'm getting an error message for the search. there may be or may have been other 550 diagrams. the topic is/was 40 or 50 pages with dozens of diagrams that covered many models.
Last edit: 25 Dec 2024 08:24 by H1Vindicator.
Re: Electrical
26 Dec 2024 07:09 - 26 Dec 2024 07:12I snagged it from Lou's website.the posted gpz550 wiring diagram is probably from the bare bones for mattylight topic. if it's still available. I'm getting an error message for the search. there may be or may have been other 550 diagrams. the topic is/was 40 or 50 pages with dozens of diagrams that covered many models.
You are right about that thread. I wonder if it could be bookmarked? Might be helpful to snag all the images from it and file them in some useful order.
Last edit: 26 Dec 2024 07:12 by TexasKZ.
Re: Electrical
26 Dec 2024 07:31
Will look at it after the holidays
