Carburetor fuel tee kit
  • 81kz1000ltdj
  • 81kz1000ltdj's Avatar Topic Author
19 Dec 2024 17:19
#907007
Hello how is everyone tonight? I'm wondering where is the best place to purchase a carburetor fuel tee kit for a 1981 KZ1000 LTD. I'm rebuilding the carbs but I do not want to put the plastic tee and other connections back in
  • Nessism
  • Nessism's Avatar
  • Away
Re: Carburetor fuel tee kit
19 Dec 2024 19:16
#907011
No personal experience...
(remove spaces)  https  ://www.ebay.com  /itm/276057497572
The following user(s) said Thank You: 81kz1000ltdj
  • TexasKZ
  • TexasKZ's Avatar
20 Dec 2024 12:43 - 20 Dec 2024 12:48
#907023
Scroll down the page a bit.
japan.webike.net/KAWASAKI/Z1000+KZ1000+A...ssories/463/1341/mc/
Edit: These are for the earlier engine, so may not fit yours. Nessism, Do you know if the dimensions are the same for the KZ and J tubes?
Last edit: 20 Dec 2024 12:48 by TexasKZ.
  • Nessism
  • Nessism's Avatar
  • Away
20 Dec 2024 13:36
#907026
Not the same.  The center feed VM fuel Tee is longer
The following user(s) said Thank You: TexasKZ
  • sf4t7
  • sf4t7's Avatar
20 Dec 2024 17:18
#907034
I got some oem style tees (made in Japan) from Z1parts.net that are very good reproductions. Fit the carbs nice and tight. Personally I prefer them over the machined aluminum with orings.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
  • 81kz1000ltdj
18 Feb 2025 12:52
#909143
I just ordered the parts today. We will see if it fits the carburetor thank you so much
  • Nessism
  • Nessism's Avatar
  • Away
18 Feb 2025 13:32
#909146
The '81 1000 should use BS CV carbs.  Can't use the older VM style fuel Tee's and transfer tubes.
  • Cra-z1
  • Cra-z1's Avatar
19 Feb 2025 06:45
#909179
I have purchased a lot of tees from this guy with good results. he should have what you need also
www.ebay.com/str/gunsbluemoon?_trkparms=...542580.m47492.l74602
