New guy from N.E Alberta
  • metltec
  • metltec's Avatar Topic Author
22 Oct 2024 17:01
#905352
Good day riders. Currently near cold lake AB. 5 yrs ago I purchased a kz650 for 3 Hun it sat for a couple years well I finally got it looking and running like it should. After removing battery and prepping for winter storage I had a brain freeze and accidentally locked my only key under the seat can anyone help in this dept. Thanx in advance.
Kevin
1976 KZ 650B1
1978 KZ 650B2
1981 Honda CB 900 Custom
2007 Harley Fatboy
2007 Harley Ultra Classic
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
The following user(s) said Thank You: metltec
  • hardrockminer
  • hardrockminer's Avatar
Re: New guy from N.E Alberta
23 Oct 2024 05:08
#905365
The old girl still looks pretty good!  Welcome from BC.
On your key...if you look at your lock there should be a number on it.  That is your key number.  You should be able to find a replacement on ebay.  If you can't see the number....it's the same number as your ignition but you will have to take the dash apart to find the number on the ignition barrel.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
29 Oct 2024 16:43
#905575
Welcome Kevin.
Being a '78 650, I believe there will be an 800 number beside the Ignition keyhole.
This is the key code number.
As mentioned, you may be able to find one on eBay.
Or I can make them as well.
Another Canadian KZ owner.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
