KZ750 1976 Engine won't start
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: KZ750 1976 Engine won't start
11 Oct 2024 00:52
#905013
Hi!
If the carb holders are tight against the carburettor, would it be sufficient to have an oring/gasket between the carb holder and cylinder block? Have anyone tried that before? Just to see if the holders are the issue before I order.
Not something I have ever tried to do ? remember tight doesn't always = sealed !
The following user(s) said Thank You: thune
  • hardrockminer
  • hardrockminer's Avatar
11 Oct 2024 05:14
#905014
When installing new carburetor boots I put a little 3Bond on them to help seal them.  Be careful to check the inside once the boots are installed to ensure no gasket seal squeezes into the manifold intake.
Have you done a compression check?  Is the air intake and air filter correctly installed when you try to run the bike?
  • sf4t7
  • sf4t7's Avatar
11 Oct 2024 05:27 - 11 Oct 2024 05:29
#905015
Looking at one of your pictures it seems you have the manifold vacuum ports connected with a tube between pairs.  Would this affect the vacuum in each cylinder's carburetor?  Those connections are for connecting to sync gauges and normally sealed with rubber caps.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
Last edit: 11 Oct 2024 05:29 by sf4t7. Reason: grammar!
  • thune
  • thune's Avatar Topic Author
09 Nov 2024 14:24
#905902
I see! It was like that when I took the bike from my dad so I kept it like that. I also saw a drawing of the assembly here:  www.megazip.net/zapchasti-dlya-motocyklo...head-cover-10414227#
Thinking that it should be connected. But I have no idea whether it should or should not be connected with the tube.
  • thune
09 Nov 2024 14:25
#905903
Thanks for the suggestion. Should there be gaskets between the boots and the engine? I haven't seen any that I can buy going from the assembly drawing. Can you point me towards where I could buy these?
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
10 Nov 2024 04:43 - 10 Nov 2024 04:45
#905912
Have seen a parts list for the 76 750 twin that shows the tube between the test ports on the carb holders and calls it a balancer tube #25 in the attached
As others have said I would get new carb holders as the current ones are close to 50 years old.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Last edit: 10 Nov 2024 04:45 by gd4now.
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
10 Nov 2024 06:31
#905915
New carb holders will also make taking the carbs off and on easier.
Don't remove the pressed in brass fittings in the carbs, just make sure they are clear. One item often overlooked is the well in the carb bowl for the choke tube. If these are clogged the engine will not be able to draw fuel through the enrichment circuit to start. I always fill the bowl with gas and make sure the well fills up as well.
Consider doing a valve clearance check as it this service item is often delayed.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • thune
10 Nov 2024 10:56
#905923
Thanks for the information. New carb holders are ordered. Had to go with eBay though. They were not that easy to find.
Looking forward to new carb holder. It has, as you stated, been difficult to put the carb on and off.
I will double check and clean the well and also get to the valve clearance check. Thank you!
  • thune
08 Jun 2025 15:08
#913506
HI all!
I just wanted to give an update on this issue. New rubber boots, new carburettor bowl gaskets and rebuilding the carburettors 6 times did the charm. I finally have it up and running now! It was amazing getting it started again!
I want to thank everybody for their input and help! Much appreciated!
The following user(s) said Thank You: Gdizard, Wookie58
