Chasing gremlins
- JoeJak73
The few questions I have are these: Does it make sense to pull the plugs that are under the left side cover to isolate problems or are those unrelated to main circuit? Secondly, even with my key off I seem to have 12 volts to the coil. Is that normal?
77 kz1000 LTD
- Thank you received: 2226
In the mean time, I would disconnect the battery. Constant voltage to the coils can burn them out.
- Thank you received: 2307
There is a link in my signature to a fault finding guide I put together (hopefully the link works) look at the section on "short circuit" faults and follow it through. Don't approach it in a random "try this and that" methodology or you will drive yourself mad. Take a look at the guide then update us, I will help you through77 KZ1000 LTD. New to me, ran like trash, cylnder 1 no fire. Turned out to be the coil. Had carbs rebuilt and I put carbs back on bike today for some tuning and popped my main fuse after a couple kicks. Put new fuse in, turned on ignition and 5 seconds later, blew fuse again. Thinking I have a wire bad somewhere. (Probably why the starter never worked as well. Guy I bought the bike from said it ran great and there's NO way this bike ran before I had it shipped to my house in CT from Iowa.
EDIT: the link isn't working (I will try and email it but the file is probably too large)
EDIT-EDIT: I have updated the link, see how you get on
In that old post if you click the attachment for the PDF it should open ??I tried the link and it takes me to an old thread where you announced posting the tutorial. I clicked on the link in your signature there and my screen scrolled down to the last post in that thread.
- Mcdroid
- Gone Kwackers
- Thank you received: 316
Same result...zooms me to the old thread...I tried the link and it takes me to an old thread where you announced posting the tutorial. I clicked on the link in your signature there and my screen scrolled down to the last post in that thread.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
did you try clicking on the attachment in the old thread ?
- Mcdroid
- Gone Kwackers
Do not see the attachment.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
i cannot see it either.
Please see below screenshot, clicking it should give the option to download ??
Edit: just seen the filebase is up and running so I have put the guide in "General-Electrical" and updated the link in my signature
- F64
- 81-KZ440D2
- Thank you received: 394
81-KZ440-D2.
LIC, NY
- JoeJak73
Another issue has risen, so I will post that in the right section.
Thank you everyone
77 kz1000 LTD
