Clutch Cable Adjustment Problem 1982 kz750 Ltd H3
- Tatonka82
11 Aug 2024 09:12
Hi, I bought a 1982 kz750 Ltd H3. The clutch cable was FUBAR and despite YouTube videos and the shop manual neither the replacement cable or the shorter gpz 750 cable with allow me to tighten up the cable and allow me to shift. I did put grease in the worm gear as it was dry but it should be working. Any help would be appreciated.
- sf4t7
Re: Clutch Cable Adjustment Problem 1982 kz750 Ltd H3
11 Aug 2024 19:38
Welcome to the asylum!
Did the clutch operate at all with the old cable?
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
11 Aug 2024 20:00
Could the helix be indexed incorrectly? Sounds like you need to move it back, which uses more cable. The arm should be at roughly 90 degrees to the cable pull angle.
12 Aug 2024 06:02 - 12 Aug 2024 06:03
Howdy. Do you have the owner's manual or service manual for the motorcycle?
If not, there's a 1980-85 FSM floating around the internet and it may be linked here in the filebase. Yellow/gold cover w color wiring diagrams.
Clutch adjustment. What direction are you turning the clutch release screw? You'll need to use the procedure in the 82 supplement section of the FSM. It's different from the directions in the main body of the manual for the 1980 models. It should be Counterclockwise first until hard to turn, then clockwise 1/4 turn. It's kind of backwards. This is how it's done on my 1981 KZ650-CSR.
Last edit: 12 Aug 2024 06:03 by martin_csr.
