New rider, new bike
  • RatRod1980
  • RatRod1980's Avatar Topic Author
New rider, new bike
13 Jun 2024 13:31 - 13 Jun 2024 14:02
#900672
Hi everybody! This is my first bike and I'm fairly new to street riding. I've got experience riding dirt bikes in my youth so I'm not averse to kick starting and counter steering (or bumps for that matter). I recently acquired a 1980 KZ650 rat bike off Craigslist. It's super dope but I'm having issues due wiring among other things. It's a custom job and is super fun to ride but right now it won't start. The rectifier grounded out a few weeks ago so I just rewired the wires together after they burned apart. Now it won't start (though it did after the fix but slowly has grown trouble starting). The battery rests at 12.90 volts but drops to around 9 when I hit the starter. So I'm sure my wiring job was the problem. I'm going to have an engineer neighbor look at it when I can but if anyone here is an electrician and can help me out, that'd be great!! Thanks!
Last edit: 13 Jun 2024 14:02 by Street Fighter LTD.
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: New rider, new bike
13 Jun 2024 14:03
#900673
Welcome to KZRider
Next time click the insert all tab to complete your picture installation
I fixed it for you this time
The following user(s) said Thank You: RatRod1980
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
13 Jun 2024 15:02
#900684
Your electric R/R (recifier/regulator) poor wiring connections will give you some kind of trouble, sooner or later !!!
Crimping or soldering connections and a double shrink tube isolation is the best way/methode to prevent those problemes !!!
Bad connections can generate a lot of heat, molten, burned plugs and oxydations due to high current/low voltage (< 12 Volt ), instead of low current and high/max voltage (>12 Volt) !!!
  • RatRod1980
13 Jun 2024 15:27
#900687
Thank you guys. I think I did pretty well with the crimping and connecting the wires, I just think I may have gotten a couple mismatched. If anyone had any idea as to my wiring job, that's why I included multiple pics.
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
14 Jun 2024 05:50
#900705
Is that orange thing a household wire nut? That's a definite no-no.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
14 Jun 2024 06:04
#900707
The best advice I can give you is make a pot of coffee, download the FSM and go through circuit by circuit comparing the bike to the wiring diagram. Trying to guide you remotely through fault finding when the wiring has been butchered is "close to impossible" as any test steps will potentially be inconclusive (guidance offered is based on the factory wiring diagram)
  • RatRod1980
14 Jun 2024 10:46
#900718
Yeah, dang. I have the wiring manual but it's a beast. I thought it'd be a simple, "the red one goes to the yellow one" but nah.. that's why I'll be asking my engineer neighbor in person asap.
  • RatRod1980
14 Jun 2024 10:47
#900720
Haha the wiring nut was one of the few connectors I had left. I presume it isn't waterproof or something?
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
14 Jun 2024 11:19
#900723
It isn't waterproof but more importantly houses don't "vibrate" which will cause it to loosen and the wiring will burn again
  • RatRod1980
14 Jun 2024 12:44
#900728
Lol oh... I appreciate the info! I'm starting to wonder though, and I might drop this in another topic, but I don't know if my wiring job is the problem now. What happens is it tries to turn over but never does. I thought it was cuz the battery dropped to 9.6 when I hit the starter but apparently that's what batteries do. It doesn't start with the kickstart either. This problem started about a week ago. The spark plugs are brand new. I think it's something to do with the fuel... Whether I set the petcock to "on", "res" or in the middle, it would run regardless. But now I'm unsure of where to set it cuz it doesn't seem to start either way! The inline fuel filter has a little darker mark on it so I thought maybe it was dirty. And the carb needles are set one mark too rich which I'll fix when I do take the carbs off one day. But for now, I'm just not sure why it won't start even though it tries to. Threw some Seafoam in the fuel and carbs last week and she was running nicely. But decided to start having trouble starting. Now it won't. I can hold the starter all day and it just won't flip over.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
14 Jun 2024 12:46
#900729
Sorry, to say but this is one of worst kind of a hack job i´ve ever seen!
