KZ440 Starter Issue - Clicking
- Lukeduke
20 May 2024 13:49
Hi Folks!
New in here, so just few words. My Name is Lukas, I am from Austria and currently trying to get my KZ440 to run before it gets converted to a cafe racer.
Today I had finally installed my new carb repair kit and wanted to try it out. The bike made 1-2 sputters and then suddenly I heard a clicking noise and the starter did not turn over anymore.
Checked the wiring, voltage and connections and did not find anything faulty so I disassembled the starter. I checked the brushes and the stator and did also not find anything faulty so I hooked up the starter directly to a Powersupply and the starter did just turn fine. So put everything back together (except the starter chain to exclude anything coming from the motor) and same as before. Even with the battery terminals connected directly to the starter no movement. Also tried a different battery, still same.
Anyone an Idea where I should start to troubleshoot? I mean if the starter turns outside of the motorcycle I guess it is not fried.
Lukas
Lukas
Re: KZ440 Starter Issue - Clicking
20 May 2024 16:32
Welcome from the UK. Bench testing a starter doesn't really tell you a lot as there is no load on it. When you say you connected the battery to the starter directly was that positive and ground ?
20 May 2024 17:34 - 20 May 2024 17:36
Welcome from Germany
Looks like a weak starter relay, the internal copper switsh could be burnd or molten.
Prüf mal bitte das Anlasser Relais und versuch mal dies bei eingebauten Anlasser über die Anlasser Zuleitung
direkt mit dem Batterie Plus zu überbrücken.
Last edit: 20 May 2024 17:36 by Scirocco.
- F64
- 81-KZ440D2
21 May 2024 23:17 - 21 May 2024 23:27
Grab your meter.
disconnect the vacuum line going from the carburetor to the petcock. This will keep the fuel off during these tests.
key on
kill switch set to "run"
meter set to DC V
red probe on positive battery post( post is the metal part of the battery)
black probe on negative battery post
note voltage
hit the starter button
note voltage
move the red probe to the starter relay big post that has the big wire coming from the battery.
note voltage
move red probe to the other large post on the relay. This post has the large wire going to the starter.
note voltage
The relay should also make a loud click when you push the starter button.
Move red probe to the positve post on the starter. Put the probe on the post not the wire.
note voltage
move the red probe to one of the metal bolts that mount the starter.
( this reading has to be as close to 0.0V as possible. It should be a steady reading as well. If it's jumping all over the place then you have a very bad ground. If it's higher than 0.5v then your ground is not great)
note voltage
turn off bike
reconnect the vacuum line going to the petcock.
key on
meter set to DC V
note voltage
note voltage
note voltage
note voltage
note voltage
note voltage
turn off bike
81-KZ440-D2.
LIC, NY
LIC, NY
Last edit: 21 May 2024 23:27 by F64.
- Lukeduke
06 Jun 2024 02:00
Hi guys!
Thanks for the answers! Finally figured it out, I was having some issues with the brushes. I ordered a repair kit and now the starter works very well. No issues at all.
Lukas
Lukas
