Identification number on motor
- KZNewbie76
07 Dec 2023 09:01
This is my second post so people know that I am not a spammer. I need help with an identification number
- Mcdroid
- Gone Kwackers
Re: Identification number on motor
07 Dec 2023 09:07
OK...what do you need?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- KZNewbie76
07 Dec 2023 13:45 - 07 Dec 2023 17:11
Could you tell me what year and what motor this is? I have kind of whittled it down to a 1981 k1000 LTD. Thank you very much I also have some pictures of the bike if you need
Last edit: 07 Dec 2023 17:11 by Street Fighter LTD.
- Warren3200gt
Last edit: 07 Dec 2023 14:04 by Warren3200gt.
The following user(s) said Thank You: martin_csr
07 Dec 2023 14:09 - 07 Dec 2023 14:10
Looks like it is an 1981 year either a “J”, “M1”, or “K1” 1000. From what I know the M1 (CSR) had a cable drive tachometer, and the J1, and LTD (K1) had electronic tach. So does the head have a hole for the tach cable or is is a solid undrilled casting boss.
Last edit: 07 Dec 2023 14:10 by Mikaw.
- Mcdroid
- Gone Kwackers
07 Dec 2023 14:18Look at the frame VIN located on the main steering stem and at the 7th letter...if it is a J, then J model, if M, then an M model, and if a K, then you have a K model. The motors for all the 998cc bikes all used J series engines.Looks like it is an 1981 year either a “J”, “M1”, or “K1” 1000. From what I know the M1 (CSR) had a cable drive tachometer, and the J1, and LTD (K1) had electronic tach. So does the head have a hole for the tach cable or is is a solid undrilled casting boss.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- KZNewbie76
07 Dec 2023 14:48
I do not have the motorcycle in front of me but I looked at the title in the 7th letter was K. Is there anything specific about the K motor? Is there anything I should know about this specific year? Thank you very much
07 Dec 2023 15:00
K would be the LTD version. Mag wheels vs spoked on the J and M1. It should have an electronic tach, no cable.
Image pulled from the net
- KZNewbie76
07 Dec 2023 15:18 - 07 Dec 2023 17:13
Last edit: 07 Dec 2023 17:13 by Street Fighter LTD.
07 Dec 2023 15:44 - 07 Dec 2023 15:49
Also, the K has an electronic speedometer rather than cable drive.
K and M had the least interesting camshafts, and less power than the other models.
Frame and engine numbers are also available here at KZR. www.kzrider.com/filebase?task=download.s...id=1178&catid=64&m=0
You can also download a factory service manual for free here. www.kzrider.com/modules/ServiceManuals/K...Service%20Manual.pdf
Last edit: 07 Dec 2023 15:49 by TexasKZ.
- Mcdroid
- Gone Kwackers
07 Dec 2023 15:49
The J series motors dropped into the M and K models are identical (except for the electronic tachometer). Whereas the J series motors for the J model had differences in timing and in jets & needles for the carbs. It will benefit you to get either a hardcopy of the shop manual (Kawasaki part number 99924-1026-01, or -02, or -03) OR I think there is a free download of that manual under the Articles tab above.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
08 Dec 2023 06:05 - 09 Dec 2023 05:09
zedder.com has some info available on their site. for models not listed and additional info, you have to get the cd.
www.zedder.com/msg1.htm
Last edit: 09 Dec 2023 05:09 by martin_csr.
The following user(s) said Thank You: KZNewbie76
