Thanks for letting me in
- moizeau
09 Mar 2023 08:45
Been popping in every now and again looking up stuff but have finally registered. My first bike after passing my test was Z250, then went to an LC, then a Zeph 550, then 1100, then a Blackbird. Sold that when I moved to France. Few years ago bought a very sorry Z1000ST, leaked from places I didn't knew existed and other bits seized that I thought were unseizable but hey. It's still an ugly beast but mechanically sound. Also got an 1100 Uni, in bits completely, bought with a seized engine, very seized. Also got another Zeph11 after regretting selling my first one. Also got a Z650 F1, fancied a moped! All bikes bought have needed work, the Zeph the least, that was just cosmetics and the CARBS. Plan to continue with the Gpz11 then move onto the 650.
Cheers all
Pete
Cheers all
Pete
Re: Thanks for letting me in
09 Mar 2023 09:46
Welcome to KZRider
We all love pictures of bikes and projects
- howardhb
- God, I trust
09 Mar 2023 10:50
Welcome Pete, looking forward to seeing your machines!
H.
H.
'81 GPz 550 D1
'82 Yamaha YB100 Fizzie
09 Mar 2023 11:08 - 09 Mar 2023 11:08
Last edit: 09 Mar 2023 11:08 by Wookie58.
- gd4now
- Denco where did you go?
09 Mar 2023 14:28
Welcome to the fun! Look forward to seeing what sounds like a nice stable of machines you have.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- moizeau
10 Mar 2023 03:57
Thanks everyone. Here are pics in chronological order of purchase. Please remember all these bikes were bought with work needed to varying degrees
As it arrived, not been run in 10 years with lots of strange parts fitted
Still a scruffy beast but now mechanically sound
The GPz11 was the next one. As it arrived
With a very seized engine
Stripped the wheels, forks, swingarm, engine casings, matt blacked the rusty downpipes and spent too much money on the carbs
Next up 'Batfink'
Now had it's clothes removed, It has got normal bars now as well
This will be attacked when the GPz is done.
There you go, not the prettiest bunch, but I like them.
Next up 'Batfink'
The following user(s) said Thank You: ThatGPzGuy, riturbo, Warren3200gt, howardhb, Wookie58, Kelly E
10 Mar 2023 05:57
Welcome aboard. That is an interesting collection. Is that a piece of a bearing under the cam chain of the GpZ?
Clearly you have a bad case of ihatemoneyitis. Sadly, there is no cure, but at least you are among friends here.
- moizeau
10 Mar 2023 08:25
Cheers, yep a camshaft bearing. The muppet who rebuilt the engine for the previous owner with an 1170 Wiseco kit lost the camchain tensioner pin. I found it in the sump during the strip. It was replaced with a bit of 4mm allthread and not set correctly. This caused the camchain to be overtensioned, ate an exhaust bearing which leapt down the centre of the engine and made love with the crank.
- blipco
- 2002 KZ1000P
10 Mar 2023 20:58
What did you do to "batfink"? (lol) She was built to run in the rain.
Oh, maybe you getting the plastics painted. Ok, I probably spoke too soon.
11 Mar 2023 08:47Some people should have their tool boxes welded shut.Cheers, yep a camshaft bearing. The muppet who rebuilt the engine for the previous owner with an 1170 Wiseco kit lost the camchain tensioner pin. I found it in the sump during the strip. It was replaced with a bit of 4mm allthread and not set correctly. This caused the camchain to be overtensioned, ate an exhaust bearing which leapt down the centre of the engine and made love with the crank.
- sf4t7
20 May 2023 19:55
And make sure their tools are inside before welding!
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
The following user(s) said Thank You: blipco
- blipco
- 2002 KZ1000P
20 May 2023 20:32 - 20 May 2023 20:32A good point often overlooked.And make sure their tools are inside before welding!
Last edit: 20 May 2023 20:32 by blipco.
