"NEW" 1978 KZ-200 Thanks for the Add....
  • WB9YLP
  • WB9YLP's Avatar Topic Author
  • Matt
09 Sep 2021 06:08 - 17 Sep 2021 13:42
#855040
Hello from Chicagoland!
Just Horse-Traded for this beauty, !!!75 miles !!! on her.
But 'Rode Hard and put away Wet'
Quick tank(not orig), carb & plug clean and still running like crap.
We'll see what unfolds with digging through the Shed Queen Resurrection process.
Looks just like my KD/KE?125 Trusty Dirt Bike  I started with in mebbe 74. My lil Putt-Putt...
Any advice {or derision} is welcome. A Biig change from my 95 Virago 1100!
Thanks!
78 KZ 200, 75 miles.
95 1100 Virago, 110Kmiles.
99 A4 Quattro, 290Kmi.
02 Merc. Sable 190Kmi.
Ham Radio since 1974...
Last edit: 17 Sep 2021 13:42 by Street Fighter LTD.
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
Re: "NEW" 1978 KZ-200 Thanks for the Add....
09 Sep 2021 10:02
#855052
Welcome to the Forum and congrats on your find.
I've had an eye out for a KZ200 for a while. There was a girl at a VJMC event in Helen, GA that had a really cool cafe KZ200. I probably have a picture of it somewhere.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
09 Sep 2021 13:14 - 09 Sep 2021 13:15
#855071
Welcome to the forum and thumps up for the good catch. 75 mile on the clock is like nothing. What´s wrong with the org. tank. We need more pics and hit the insert all button next time. You will find a service manual(s) in the data base
kzrider.com/filebase/category/8-kz200
EDIT: Thank you to the unkown uploader of the 5th. edition of the KZ200 FSM
          A "what´s new" hint to the new added data base files would be a great/helpful forum upgrade
Last edit: 09 Sep 2021 13:15 by Scirocco.
  • WB9YLP
  • Matt
17 Sep 2021 10:40
#855407
UPDATE 9/17 Well, Guys, hadn't set Points in a long time! the Dwell-light-bulb method still works well! Wanna try Stock 1st, then mebbe E/I
ANNOYING that the Oil Filter's in the Engine Case!
BAD NEWS, while the oil was still clear brown when drained it did smell Gassy... pulled carb off and did a compression check
60psi cold, carb off WOT dry  90psi with a 1/2 shot of 80-90.. It's bleeding at the head gasket. The AW S--T of the month... GRRRRRrrrrrrRRRR.
My forensic de-construction guess is O/O left petcock on and cranked into a hydro(gas)-locked engine blowing the head gasket bitd...
The KZ-200 seems to be somewhat a Red-Headed Stepchild. Simple enough engine, though shouldn't be too tough...
Lurking the nether-regions of the Internet for a Head Gasket set.
OR Sell, if the Offer's Right.....any pointers?
  • TexasKZ
  • TexasKZ's Avatar
17 Sep 2021 15:56
#855419
Partzilla shows them in stock.
You will need at least reference numbers 14, 15, 17 and 20.
www.partzilla.com/catalog/kawasaki/motor...linder-head-cylinder
  • WB9YLP
  • Matt
18 Sep 2021 09:26
#855446
TEX;
Yup I saw the 'Donut' style OEM;
The inbound one is a 1 piece aftermarket that seemed to be the consensus 'Upgrade, Fix' for the issue...
Draining the Gas tank and lurking my Electronics budds for Ferric Chloride to 'Gun Brown' the inside of the gas tank so it'll never rust from the inside. [15Y so far on my Virago]
Looks like I'll have 2-3 weeks for a good 'pickling' on the steel 2 stroker tank that came with it... I may Lurk for a stock tank, dunno...
Anyone have period KAWASAKI tin for the tank [KD,KE 125 style?]
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
19 Sep 2021 10:33 - 19 Sep 2021 10:34
#855476
I think you are overthinking it.  Probably just stuck rings. Clean the carb, tank, points, install a new battery and run some premix through it.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Last edit: 19 Sep 2021 10:34 by Kidkawie.
  • WB9YLP
  • Matt
20 Sep 2021 10:48
#855529
Not Stuck Cranks & runs, though!
Naaah at 18HP in full high compression shoving my 250lb butt around It'll need all the compression it can muster.
Parts inbound, Rainy day so I'll clean off the workbench for the new gasket job...
The Definitive test was when the compression test oil was blowing/leaking out around the head-to-block seal...
  • WB9YLP
  • Matt
20 Oct 2021 15:32 - 20 Oct 2021 15:33
#856845
The Saga continues!
Got the head  & gasket off and scoured the 'donut' rest and head where exhaust/power was leaking, smoothed out blowtorching, still flat in daylight...
Reassembling tomorrow!
Attachment not found
Last edit: 20 Oct 2021 15:33 by WB9YLP.
  • WB9YLP
  • Matt
04 Nov 2021 08:15
#857376
The Adventure Continues!
Lurching forward...
Trust Nothng in anything this old...
PO had set the Valve Lash too tight, Glad It hadn't been run much with it that tight...
130psi open intake now...
Did manage to 'Snag' an extra '79 engine/trans carcass and an extra head!
Bottle start soon!
  • WB9YLP
  • Matt
11 Nov 2021 15:14
#857808
IIITTTSSS           AAAlLLIIIIIVVVEEE!!!
Browned Gas tank, Cleaned carb, Head Gasket Cleaned Head/Jug  oil galleys, Cleaned & set Ignition Points, Valve Lash reset...
Carb's inconsistant and rubber's probably dried out... Any recommendations, VM22/26 & jetting?
  • WB9YLP
  • Matt
01 Dec 2021 09:33
#858517
After beating my head on the KEHIN and discovering the rubber O-Rings had dissolved I figured a new carb was far less expensive than fixing the old one.
I still haven't run it more than a mile or 2 since then but it's holding a consistant idle and kicks on the first crank.
More in Spring when I can put 40-50 miles or more on it and check plug flash....
This one Fits and seems to work.Carbman YFS200 CARBURETOR ASSYChoke button bumps against stock petcock(leaky) so I replaced it with this;QAZAKY 2pc Fuel Petcock Valve Switch Compatible with Kawasaki Bayou 220 300 400 KLF220 KLF300 KLF400 KL250 KZ305
The following user(s) said Thank You: KZJOE900
