Offset sprocket
- Stillridinum
Offset sprocket
09 Jun 2020 15:16
Hello, my current project is a 1982 KZ1000 LTD, I have installed a swing arm from PDM along with a 5/8 offset front sprocket. I am unable to use the stock safety lock washer system that was on the original front sprocket,is locktite acceptable?
Thanks
Thanks
1982 kz1000 LTD +6” arm from PDM
1980kz440
1998 flsts
1980kz440
1998 flsts
- zed1015
Re: Offset sprocket
09 Jun 2020 16:05
Yes! Loctite should do the trick if the nut threads on fully or use a clutch hub nut as they are the same thread but of the locking type.
If it's just the lack of hole for the tab washer a cobalt bit will drill the hardened sprocket.
- Stillridinum
Re: Offset sprocket
09 Jun 2020 17:12
I will have to go with the locktite then because the sprocket is secured with a bolt, thanks for the help!!
1980kz440
1998 flsts
1980kz440
1998 flsts
