First bike. KZ750 ltd
  • artsgotagun
  • artsgotagun's Avatar Topic Author
24 Apr 2020 15:58
#824175
Found this 1980 Kz750 ltd and had to get it. I had been looking for a project bike for awhile and stumbled on to this. Im going for a brat/cafe mix up. Here it is when i just got it home last thursday. As of right now its torn apart...lol. Needs a lot of little things the more i dig into it and this site has been amazing thus far/
  • riturbo
  • riturbo's Avatar
Re: First bike. KZ750 ltd
25 Apr 2020 03:08
#824215
Welcome . Nice bike . Don't see them in that shape very often . Be a shame to cut that up . Maybe ride it for a bit you might find thats shes fine as is .
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
25 Apr 2020 05:38
#824220
Why butcher it? That's a serious waste of a nice machine. Ed
  • M_a_t_t
  • M_a_t_t's Avatar
25 Apr 2020 07:31 - 25 Apr 2020 07:47
#824233
I'm with the others, but I'd be interested in the handlebars, turnsignals, grab rail, and possibly seat/seat pan if you replace those parts in your conversion.
Edit:
I'm not sure what I was thinking. I already have the ltd parts, but my bike isn't an ltd. I need the e2 parts. Grab rail is the same though I think.
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
Last edit: 25 Apr 2020 07:47 by M_a_t_t.
  • artsgotagun
25 Apr 2020 19:35
#824288
Whoa, whoa....nothing is getting butchered as of yet...lol. Thats the overall goal but right now, the plan is to comb through it maintenance wise. I have already ordered most of the parts. Just the waiting game. Needs new tires, fork seals, wheel bearings, spark plugs, oil change and a good carb clean. Going to do all of that and just ride the shit out of it this summer.
  • Nessism
  • Nessism's Avatar
  • martin_csr
  • martin_csr's Avatar
26 Apr 2020 05:05 - 26 Apr 2020 05:15
#824300
Howdy. Since it wasn't mentioned, you might need to replace the brake lines, since old old old rubber lines can burst. As for the bearings, I was going to replace mine on the original wheels, but after taking a look, the grease looked new, so I left them in there. I just added some extra grease as a just in case. hee. In regards to maintenance, it's probably already on your list, but be sure to clean, check & lubricate the timing advancer. you could do this the same time as the valve clearance check. order a new RH engine cover gasket beforehand. Anyway, good luck.
ps: in case you aren't aware, there's an 80-85 750-4 chain drive pdf manual available.
Last edit: 26 Apr 2020 05:15 by martin_csr.
The following user(s) said Thank You: artsgotagun
  • artsgotagun
27 Apr 2020 11:00
#824408
martin_csr wrote: Howdy. Since it wasn't mentioned, you might need to replace the brake lines, since old old old rubber lines can burst. As for the bearings, I was going to replace mine on the original wheels, but after taking a look, the grease looked new, so I left them in there. I just added some extra grease as a just in case. hee. In regards to maintenance, it's probably already on your list, but be sure to clean, check & lubricate the timing advancer. you could do this the same time as the valve clearance check. order a new RH engine cover gasket beforehand. Anyway, good luck.
Will do on all of the above. It's been neglected and would like to give it the love it deserves.
  • artsgotagun
08 Jul 2020 20:39
#830142
Well, heres an update on the bike. Finally got it running this week. Noticed it starts to break up in the higher RPMs.
The following user(s) said Thank You: Scirocco
