Carburetor problem
- Danny Millhorn
Carburetor problem
23 Jul 2019 19:59
Rebuilt carburetors on 1975 z1900. Only runs with full choke. What's wrong?
Re: Carburetor problem
24 Jul 2019 02:28 - 24 Jul 2019 02:34
I suspect that the pilot circuits are not yet perfectly clean.
Wear eye protection while spraying carb clearer because the spray always backfires. ALWAYS .
Pay extra careful attention toward cleaning the orifice into bottom of the car bore (number 6 on the following diagram).
Last edit: 24 Jul 2019 02:34 by Patton.
The following user(s) said Thank You: Danny Millhorn
24 Jul 2019 02:48 - 25 Jul 2019 00:05
The carbs at hand may have the pilot mixture screw instead of the "pilot air screw "as shown in the earlier diagram.
Both style carbs have an orifice into the carb bore.
Last edit: 25 Jul 2019 00:05 by Patton.
24 Jul 2019 05:28
What do you mean when you say you rebuilt them? What did you change? Are these the original carbs? What serial number is the engine?
- Danny Millhorn
24 Jul 2019 15:19
The bike has been off the road since '84. Installed carb kits in all 4 carbs, however once I got into it I realized there are part variances and just because the gaskets fit doesn't necessarily mean the jets etc., are right so it's possible I installed the wrong parts. I believe the carbs are original. As for the engine serial number, I will need to look .
24 Jul 2019 15:48
The reason I asked for the engine S/N is because they switched carbs mid year for 1974. Up to S/N 35,000 had the Z1 style carbs with different jetting than the rest of Z1A bikes, which used the same carbs as the Z1B.
25 Jul 2019 05:33
I think I made a mistake. I thought the bike was a '74 but I see now that it's a 75. Stock carbs would be VM28SS. Pilots would be 17.5 and mains would be 112.5. Air screws should be out 1 and 1/4 turns from lightly seated. Needles should be 5J9 with the clip in second position from the top. Jet needles are O8.
What parts are currently installed?
- davido
25 Jul 2019 05:55hardrockminer wrote: I think I made a mistake. I thought the bike was a '74 but I see now that it's a 75. Stock carbs would be VM28SS. Pilots would be 17.5 and mains would be 112.5. Air screws should be out 1 and 1/4 turns from lightly seated. Needles should be 5J9 with the clip in second position from the top. Jet needles are O8.
Wow! The joy of forums. There you have it. What more could you ask for!!
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- Danny Millhorn
25 Jul 2019 20:40
The engine s/n is:Z1E059149.
BTW should the engine S/N be the same as the title ID #? Mine are different.
- slmjim+Z1BEBE
26 Jul 2019 04:48Danny Millhorn wrote: The engine s/n is:Z1E059149.
Title should have the frame VIN, starting with Z1F- if it's really a Z1 frame.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
26 Jul 2019 05:35
That S/N is definitely a '75. If your intake and exhaust are stock then the parts I described are correct for the carbs.
Did you rebuild them? If so, what did you do?
When I rebuild them I take everything apart and wash parts in an ultrasonic bath. Then blow compressed air through all the holes, particularly the three small orifices on the intake side to ensure they are clear. I use all new jets and needles and throw out the old ones. Use new gaskets for the bowls and tops. I like the Keyster kits sold by Z1 Enterprises.
