New Member: '82 305
- 305CSR
New Member: '82 305
05 Jun 2019 16:57 - 05 Jun 2019 16:59
Hello all,
I have an 82 305 CSR. I haven't ridden in about 5 years and I'd like to get it going again.
Last edit: 05 Jun 2019 16:59 by 305CSR.
- Deadulus
Re: New Member: '82 305
05 Jun 2019 18:36
Hi, thats about how long its been since I've been able too and one reason I got my KZ650. Its gonna take love to get it going, but hey. Good luck with your endeavour!!
- 305CSR
05 Jun 2019 18:42
I got it all sorted out before I quit riding it and it was running great, but then I had a timing chain tensioner issue and then 2 kids came along. I posted about the chain tensioner in another thread. I just had the carbs rebuilt and I don't run ethanol gas, so I'm not sure what shape they'll be in.
- KZJOE900
- Administrator
Super Users
09 Jun 2019 09:10
Probably in pretty good shape if the carbs have just been rebuilt. Probably have to get them tuned and synced. Check the tank to make sure there is no debris coming from the tank prior to attaching the fuel to the crarbs. Otherwise, you may need to clean the carbs again if the debris gets to them. You should install a inline fuel filter to avoid this as well. The first time starting it, a two or three shots of starting fluid to each carb bore will help things a long. Best of luck.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
