Offset valve inner tube
- mantracker
24 May 2019 22:57
I am looking for an heavy duty inner tube with an offset valve, 2.50 X 12. It goes on a Zoom chair. I am in a wheelchair and this is a chair for handicap to be able to go off road. The valve comes out the side rather than straight up the center like we have in the United States. It's made in Sweden so I assume the inner tube is European. Can anyone help me find 4 heavy duty tubes?
Re: Offset valve inner tube
25 May 2019 01:04 - 25 May 2019 01:08
Here are some links for you
www.eet-kessler-shop.de/Schlauch-12-1/2-...er-E-Mobil-Rollstuhl
www.amazon.de/dp/B072C6SDCX/ref=sspa_dk_...e9-a88f-0353b2786e42
www.ebay.de/p/Schwalbe-Schlauch-Nr-1-12-...992?iid=311857644560
Last edit: 25 May 2019 01:08 by Scirocco.
- mantracker
25 May 2019 07:13 - 25 May 2019 07:14
mantracker wrote: "Have you ever heard of offset valve before? "
Considering that Scirocco posted 3 links to and a photo of an offset valve your question seems rather odd. Ed
Last edit: 25 May 2019 07:14 by 650ed.
- ned37
25 May 2019 09:49
also note in this chart the tr numbers which demonstrate the different valves and their placement.
kenjonestiresblog.com/wp-content/uploads...ct-Catalog-Tubes.pdf
'83 GPZ1100, '97 Triumph Trophy 1200, '08 Husky TE610
Verde Valley, AZ
Verde Valley, AZ
25 May 2019 10:23 - 25 May 2019 10:27
Having resorted to joining a Kawasaki motorcycle forum in order to ask this question, I would suspect that you've already done a plethora of research on the web through Google, etc., without having found what you're looking for.
If not already done, you might want to try submitting this inquiry via the live chat feature in the following link:
click here > livingspinal.com/power-assists/zoom-all-...HEAQYBSABEgLknPD_BwE
The link says "Tires 16×2.5” air-rubber tire with cross tread pattern." :huh:
Last edit: 25 May 2019 10:27 by Patton.
25 May 2019 11:59 - 25 May 2019 11:59
Here is how I roll when in need
Great for outdoor mobility and hunting
I also plow my snow with it
Last edit: 25 May 2019 11:59 by Street Fighter LTD.
- mantracker
25 May 2019 15:58
I do have a tracked wheelchair. I live in a rural area and use it to work around my place.
- mantracker
25 May 2019 16:03
I check the links and they had bent valve. I am wondering because the tires say Czech Rep. on them. Could this be the difference because of country?
- slmjim+Z1BEBE
26 May 2019 08:15
Consider a cross-section of a common motorcycle tube, where the stem is located at 12 o'clock, regardless of the angle of the stem.
12.5" tubes are available toward the bottom of this page:
livingspinal.com/power-assists/zoom-all-..._Wt6NXhoCaZ8QAvD_BwE
Good Scootin'
slmjim & Z1BEBE
If we read this literally, are you saying the stem is located at ~2 o'clock (or ~10 o'clock)?mantracker wrote: The valve comes out the side rather than straight up the center...
Good Scootin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- mantracker
26 May 2019 09:47
yes, that's correct. I didn't realize the valve was coming out the side till I went to bike shop and he said he couldn't get that kind of tube. If he put a straight valve in it, it would cut the valve.
