Police two seater
- kz-recruit
Police two seater
22 May 2019 17:05
Been a member for a few months now, but first time I decided to post. I picked up a KZP last year and have slowly been working to bring it back to its glory (replacing fuses, valve adjustment, oil seals, etc.).
I just ordered a two up seat from ebay. Given the amount of times I've read through the postings on here about passenger seats thought it would be a fitting first post.
I'm sure it will fit, just a matter of how much effort I am going to have to put in to make it fit. I plan on posting again once it's on.
Post had it listed as a vintage KZ 1000 seat from the 70's.
91 KZ1000P
05 S40
05 S40
Re: Police two seater
22 May 2019 17:25
Try searching the archives here for threads on kzp seat. As I recall, it takes a good bit of work to convert to a civilian seat.
23 May 2019 05:32
I don't know anything about changing the seat, but is the motorcycle an early 1000C Police bike or a KZ1000-P? When searching, it may help to differentiate between the two as there are probably differences between them.
- kz-recruit
26 May 2019 19:33 - 26 May 2019 19:35
The seat did not fit. Not quite long enough and no allowance for fuel tank mounting transverse frame. Still looking.
I saw a thread that showed a CSR seat fitting perfect on a KZP no mods needed. However, these seats seems to be pretty hard to come by.
Also, can't believe I was so optimistic on the first post.
91 KZ1000P
05 S40
05 S40
Last edit: 26 May 2019 19:35 by kz-recruit.
26 May 2019 20:13
I am pretty sure the CSR and LTD seats are the same.
- kz-recruit
09 Jun 2019 09:20
Yeah picked up a CSR seat off the ebays and fits pretty good. Need to bend the rear mounting hinge because it sits a little off center but other than that perfect.
91 KZ1000P
05 S40
05 S40
The following user(s) said Thank You: KZJOE900
