Hello from Utah!
- renrip
Hello from Utah!
09 Mar 2019 19:07
Recently purchased a smooth running 1980 KZ550A with 10800 miles for $500. As you can see from the pictures it’s not in the best condition cosmetically, but mechanically everything seems sound. The previous owner had already run through the carbs and jetted them for pods as the original air box was missing when he bought it. (I know...) He works for a reputable custom bike and service shop here, and has been giving me free help while I’ve been checking things out.
Within the next week I will be going through the service schedule to get it up to date to the mileage it is at then going through all the hoses, connections, etc.
The only issue I have been trying to figure out is the starter button. It and the solenoid have power, but it will not crank with the button. However, it will start by bridging the solenoid terminals. I’ve been reading as much as I can about the ignition system and going through the diagrams. I have a replacement solenoid that I will be testing next weekend. Hoping it is as simple as cleaning up the connections but may have to go through the wiring harness... any pointers for checking this system?
Parts it needs as of now: new horn, chain and sprockets, seat cover(on the way), rear drum shoes, front tire (rear is in great shape though I will be purchasing as a set just in case), fork seals and dust boots. There is sure to be more in the future..
Looking forward to participating and learning from all the knowledgeable folks here
1980 KZ550A-1
- bluej58
Re: Hello from Utah!
10 Mar 2019 11:36
No eBay APP ID and/or Cert ID defined in Kunena configurationWelcome renrip
If you are pushing buttons and nothing is happening you should pick up a can of this stuff and do (every) connection front to back, Great stuff!
Clean the connections first then check if needed.
Where in Utah?
My wife and I rode the heck out of Southern UT, Loved it!
Where in Utah?
78 KZ1000 A2A
- renrip
10 Mar 2019 16:49
De-Oxit is definitely on the list of things to pick up! Thank you for the suggestion though. Didn’t have much time to check everything out in the control pod unfortunately.
I’m up north near Salt Lake actually. Absolutely beautiful state! Planning on taking a short hammock camping trip that way once I feel confident in the KZ.
1980 KZ550A-1
- rstnick
17 Mar 2019 18:12
Welcome.
With just over 10,000 miles, she should have lots of life left in her.
Did a solenoid swap fix the starting issue?
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- renrip
17 Mar 2019 22:46
Thanks, excited to learn as much as I can about these bikes. Have already benefited from the vast knowledge base here!
Motor is strong! Huge difference between the KZ and my prior bike which was a 77 Yamaha XS500D though it has only 2 more horsepower. That bike was in awful condition, as well as a major lack of parts available...
Took her for a short ride after charging the battery that came with it (will be buying a new battery soon) and she rips! Such an enjoyable bike to ride.
After going through all the wiring and swapping out the solenoid just in case, turns out the spring fused itself to the plastic starter button. Should have checked that first :laugh: Easy fix as I have a spring I can use as a temporary replacement until I order a new button.
Will be titling and getting her registered this week.
1980 KZ550A-1
