Kz1000 history?
  • Jjr
  • Jjr's Avatar Topic Author
Kz1000 history?
07 Jan 2018 01:40
#777029
Hi, I'm new to KZRider and recently bought the bike below which I got from a shop in the UK, they had imported it from the USA, Minnasota. I know nothing about the history of the bike. I was wondering if anyone in the USA recognised it as there are lots of members on here that are from the USA.
Thanks for any info.
  • missionkz
  • missionkz's Avatar
Re: Kz1000 history?
08 Jan 2018 14:55
#777078
Looks like there could be a few different year parts on that one.... how is it to ride?
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • Jjr
Re: Kz1000 history?
09 Jan 2018 12:00
#777112
Not had chance to ride it yet as when I got it, it ran on 3, it's now on 4but I'm awaiting parts to service it as it's kicking out black sooty smoke.
Cheers
  • mopguy
  • mopguy's Avatar
Re: Kz1000 history?
09 Jan 2018 14:45 - 09 Jan 2018 14:45
#777120
It looks like it can be any of these 1977,78.79 or 1980 KZ1000 Ltd., however if you post your serial number on the neck of the frame someone here will tell you exactly what year and model you have.
Last edit: 09 Jan 2018 14:45 by mopguy.
  • bluej58
  • bluej58's Avatar
Re: Kz1000 history?
10 Jan 2018 03:17 - 10 Jan 2018 03:18
#777140
Engine numbers also
78 KZ1000 A2A
Last edit: 10 Jan 2018 03:18 by bluej58.
Re: Kz1000 history?
10 Jan 2018 06:35 - 10 Jan 2018 06:38
#777145
"Zedder" has some good info about ranges of VIN and Engine serial numbers on various model years
May begin research by clicking > www.zedder.com/msg1.htm#Kawasaki
Likely have to check several models before finding the one with VIN or Engine number range that includes the numbers on hand.
It's not unusual to discover that a bike at hand has had its original engine replaced with an engine from a different year model.
Good Fortune! :)
Last edit: 10 Jan 2018 06:38 by Patton.
  • Jjr
Re: Kz1000 history?
10 Jan 2018 11:45
#777155
Thanks, I'll take some pic's of both numbers.
  • Jjr
Re: Kz1000 history?
11 Jan 2018 08:55
#777199
Hi, I don't know if anyone here can give me any info on the numbers?
  • bluej58
  • bluej58's Avatar
Re: Kz1000 history?
11 Jan 2018 16:42 - 11 Jan 2018 17:00
#777213
It's a early 1978 kz1000 A-2
I think you got the frame number slightly wrong,, there should be 00 before the A
www.zedder.com/Info/78%20KZ1000-A2.htm
The wheels, brakes and swing arm could be from a 77 LTD like this
78 KZ1000 A2A
Last edit: 11 Jan 2018 17:00 by bluej58.
  • Jjr
Re: Kz1000 history?
12 Jan 2018 07:13
#777230
Thanks for the info, I had missed the oo off the number. Looks like my bike is a bit of two!
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
Re: Kz1000 history?
15 Jan 2018 21:36 - 15 Jan 2018 21:37
#777320
Jjr wrote: ...Looks like my bike is a bit of two!
Is the front wheel an 18" or a 19" diameter? The front disks have the hole pattern from a 1978 Z1R. If the front wheel is an 18", the wheel and disks are likely from a Z1R.
My dad's '74 Z1
'00 ZRX1100
Last edit: 15 Jan 2018 21:37 by DOHC.
  • kevski
  • kevski's Avatar
Re: Kz1000 history?
17 Jan 2018 13:11 - 17 Jan 2018 13:16
#777369
It's an A1/2, rear wheel from a ltd the A1/2 had option for cast wheels but the rear was an 18 not a 16.
Carbs are CV's and are wrong also the pods will make it run like a dog, original carbs would have been Mikuni 26mm's, your air box is missing and they are as rare as rocking horse sh*t.
grab rail is ltd as is the seat, wrong handle bars as well.
The one piece of advice i can give is get a proper airbox for those carbs probably a csr 1000 one will fit or go back to 26mm mikunis with correct airbox not cheap but worth it, look at paying a couple of hundred for the air box and 250 for the carbs Pound notes that is.
drilled disc are fine, in fact an improvement on the originals, these are nearly useless as opposed to originals which were/are useless.
As you are in the UK it would be worth joining the Z1 owners club forum, pretty helpful bunch, some use this site as well.
Last edit: 17 Jan 2018 13:16 by kevski.
