KZ Project is process!
- Joey M
02 Nov 2005 07:07
Hello all,
Great site! I have learned a lot from browsing over the last few weeks & just joined up.
Attached is photo of my 76 KZ900 in the final stages of deconstruction. I have already assembled rear suspension with swingarm and alloy disc brake spoked rear rim from a GS1100. In the background is my front setup, an Akront alloy spoke from gs1000.
I have another set of forks lowered 2" & plan on finding some 2" shorter springs for the back.
- jenshhj
Re: KZ Project is process!
02 Nov 2005 07:19
Welcome onboard! Nice and clear picture of your bike.
Sounds like you have some work ahead converting the rear to a disk, hopefully the swingarm swap will be easy.
Is the lowered front end from a GS as well? If not, is the GS front wheel assembly going to fit onto a KZ front end? Seems like lowering the bike 2" front and back will make it pretty low - hope you're not too quick in the turns, and make sure you have an exhaust with good clearance, maybe a side winder.
- Joey M
02 Nov 2005 07:57
Thanks,
The swingarm swap looks to be pretty straight forward, just a matter of shimming the pivot tube width.
The front end is a KZ900, It's interesting you mention the front wheel fit-up because I am in the process of trying to figure that out right now! Maybe someone else here has done this?? Looks like it needs a longer axle and some adapter spacers.
I do have a beat up V&H sidewinder for the bike, & have a master from a KZ which I need to weld tabs on for. Looks like others have relocated the pegs to acacommodate the header.
I'm sure I'll be looking for more help here!
- zedheadmc
02 Nov 2005 22:13
Howdy!! Just curious, are those Fox Shocks on the rear of your bike? Speacking of bike I believe you are going to have one very sweet looking one when finished.
- Joey M
03 Nov 2005 07:24
Thanks,
The shocks are by Progressive Suspension installed by previous owner back in about 1985!
